Question about JoWood Productions Neighbours From Hell 2 for Windows
The image doesn't move when i look to another location
When i press something the half of image only changes
Philips 42PFL5405h/12 - Black screen and no audio on turning on.
It sounds that the settings have been corrupted. It will be best to contact the authorized service center to make this set right. Beware, not to make any experiments hereafter. It's 'PHILIPS'
Jun 24, 2013 | Philips Televison & Video
As you can see, the screen isn't full, its kinda half, mom pressed something and i don't know how to fix it, please help.
The issue here is the "Format" or "Ratio" of the screen. Currently, it is set to Standard Format or a 4:3 ratio. It may also be set to 480i or 480P scan rate.
You should change it to Wide Screen or 16:9 ratio. Additionally, you will want to display High Definition images by selecting a scan rate of either 720P, 1080i or 1080P - depending on which choices are offered by the TV. Typically the remote will offer a choice of Format. It is possible that the source device (cable TV, DirecTV, Tivo, etc. has a command to cause this too. In any case, the TV, and other source appliances must be set to Wide Screen / 16:9 and 720P or higher to veiw full screen, HD images.
I hope this helps & good luck!
Mar 05, 2013 | Televison & Video
My cursor on my HP doesn't work. don't want to use a mouse.
i'm sure that there's a button to lock the trackpad,it's near the panel.you need to press it once again to turn the panel on
I think it's right above the trackpad
or look on your laptops keyboard for a picture like trackpad press it with the function Fn button at the same time
or it should be the hardware
the trackpad cable maybe doesn't installed properly,not locked or something
Aug 20, 2012 | Computers & Internet
Why do my john deere445 moves at half its speed even when petal push all the way down
is the belt slipping?is the linkage points loose and the pedal doesn't have full travel the rod should have some adjustment to take up the slack
Aug 17, 2012 | John Deere Garden
Screen does not light up - stays black
remove charger,
remove battery
press and hold the power on button for 1min
place battery
press power on button,
if it doesnt light up, then check your memories chips. try another one
good luck
Jun 19, 2011 | Sony VAIO Notebook
DOWN LOAD PICS FROM PC TO PHONE
Basically, you just mount your phone via USB and place the images on the sdcard. Ideally you would want to create a Media\Wallpaper folder or something to put them in to stay organized.
Once the images are on your phone, you unmount, long press on any open area of your screen and select set wallpaper (or hit Menu > Wallpaper). Then choose gallery and you should see whatever folders you dumped them into. It will scan the entire sdcard so their location really doesn't matter, it's more of an organization thing as I said.
You could also just text them to your phone, or send them to gmail and download directly through your phone without having to mount it.
May 16, 2011 | HTC Inspire 4G Smartphone
After some shots an ERR message appeared on LCD, I could not make more picture. The error message in the counter field (when half pressing) the shutter is r09. I tried to take in and back the battery, the...
"ERR" doesn't indicate any specific error, but usually tends to be something only a technician can fix. Sometimes, you can make it go away by fully pressing the shutter release, but chances are that it will reappear at some point. Take it to a reputable camera shop, or send it to Nikon if you're still under warranty.
(The "r09" message is not an error, but an indicator of how many images you can take-nine in this case-before the camera has to pause for processing. This usually applies to burst-mode photography, and varies depending on how fast your CF card can transfer images.)
May 15, 2011 | Nikon D80 Digital Camera
How do you transfer photos on a kodak m863 from internal memory to an sd card?
Insert a SD memory card. Set the camera's image storage location to "internal memory". Press the Review button, then press the Menu button. Use up/down to highlight "Copy" then press OK. Select an option and press OK.
To set the camera's image storage location, press the Menu button then use up/down to select "Image Storage." Don't forget to change it back when done.
Hope this helps.
Apr 28, 2011 | Cameras
SI686
To activate the sound soother press the round button on the bottom left of the unit marked soother. To change the Soother stations press the "Tuner buttons either left or right. The tuner buttons are located on the bottom half of the unit above the volume buttons. one click of the tuner button moves one station on the sound soother selection.
Jul 06, 2008 | Sharper Image SI686 Clock Radio
JoWood Productions Neighbours From Hell 2 for Windows Logo
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
