Question about Cycling
How to adjust front gears on Huffy Stalker DS
4 Suggested Answers
  • 5 Answers
SOURCE: Gears on bike to tight to sift gears
the store that hires ppl to assamble theses bikes have no clue what there doing tuey get paid by the piece you dont kow how many errors i see im suprised no one has fiked suit against a company example toys r us, walmart, target, sport athority, target..i would reccomend just taking it to bike shop or return to where you had purchased your bike from and demand another one. and test before you take it home to make sure all gars are working and shifting fine.
Posted on Apr 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: can I replace the back
That's up to you and your abilities and available tools...
http://www.parktool.com/blog/repair-help/categories/hub-service
Posted on Apr 07, 2011
xclubcar98x
  • 111 Answers
SOURCE: my huffy stalker fs front
Tighten the bolt that is in the center of the handlebar piece. As well as the nuts/bolts on the lower part of the shaft that comes up and connects to the handle bars. Hard to explain. But just align things right, and tighten everything up on the entire wheel/handlebar assembly.
Posted on Jun 09, 2011
Got my brand new huffy a few weeks ago. everytime I shift gears, the chain comes off. we try to adjust the Derailleur, but the front one don't go all the way to the large sprocket. what do
If you purchased from a reputable bike dealer take it back. I have never heard of a dealer who does not offer a free checkup when the bike is a few weeks old because cables do stretch.
Sep 12, 2014 | Huffy Cycling
How do I adjust 7 speed shimano on Huffy?
Cable adjustment is complex. Suggest taking your bike to local bike shop for assistance
Sep 08, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Gears in front handlebars fell out
Do You mean the GEAR SHIFTER fell apart? There are no gears in the handlebars.
Mar 29, 2013 | Huffy Mens DS-5 Mountain Bike
Huffy stalker 18 speed, I can't tighten the stem.
If you are talking about the handle-bar stem, the bolt you need to tighten is right in the middle of the post. It may have a snap-on plastic cover over it. This will be the head of a long bolt that reaches down inside of the stem where the nut is shaped as a wedge that serves to tighten inside the tube of the front fork. If you are talking about the the seat-post, then your seat-post might be of too small diameter.This page shows a good picture of the handle-bar stem bolt and wedge nut.
http://www.bikewebsite.com/bikeoh.htm
Mar 03, 2013 | Cycling
My huffy stalker fs front wheel and handle bars keep getting off misalgnment
Jun 09, 2011 | Cycling
Just purchased a Huffy bicycle today from Academy - I have never had a bicycle with gears before - Is it normal that the gears switch when you don't switch them? This is all new to me!
The rear derailleur needs to be adjusted to stop this from happening. Put the bike in third gear and flip it over onto the seat. Spin the wheels and turn the adjuster until it starts to try and shift into 2nd, then back it off a couple of clicks. Problem solved.
Feb 23, 2011 | Huffy Cycling
How do I fix the handle of my huffy blackwater women's bike so that it synchronizes with the wheel?
Try this website and look under repair help:http://www.parktool.com/index.asp I think you are try to adjust your derailleurs. Also check this website under gear shifting:http://sheldonbrown.com/gearing/index.html I hope this will help.
Aug 10, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
The chain wants to jump off while trying to change gears
There are several things that could be wrong:
Shifter out of adjustment
Chain worn
Chain and gear(s) worn
Shifter out of adjustment:
Try adjusting the cable tension by turning the barrel (the part between the cable and the shifter). Count the number of turns and reset it to its original position if this doesn't solve it.
Chain worn:
Chains wear out. hold a ruler up to it, with one end centered on a pin. 12" away, another pin should like up very very very close to the 12" mark. If not, it's probably worn out and needs to be replaced. No way around it. Some say chains are good for 500 miles only. Your mileage may vary. (keep reading...)
Chain worn and gear(s) worn:
If the bike has been ridden witha worn chain for a while, it will make the gears in the back wear faster too, and a new chain alone will not work. If this is the case, you need a new chain and new gears in the back. Often, gears in the back are replaced all at once in a 'cassette'. You'll have to make sure your front gears aren't worn out too!
Nov 15, 2008 | Huffy Cycling
Cycling Logo
79 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
