Question about Toshiba TEC B-SX4 Thermal Label Printer
Smartforms printing to TEC B-SX4 in SAP
Having trouble printing to label printer from smartforms in SAP
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
This may be because the instructions are truncated.
Check by using the dump function on the machine
Posted on Dec 09, 2013
3 Suggested Answers
  • 254 Answers
SOURCE: Label over run
Check the size of the label in your codes or driver.
The length must be correct or else you cannot use it correctly.
You must may be recallibrate the sensors
Posted on Sep 03, 2009
  • 254 Answers
SOURCE: TEC SX4 Label printer received
How do you communicate with the printer?
If by serial check the speed parity etc frma the parameter menu
Else check that the character selecter for esc sequence is correctly programed els choose Auto.
TO en ter parameter settings
Switch on with feed and puase key pressed. When (1) diag V XX displayed press feed
(2) parameter is displayed.
With the pause button you can navigate in the menu and feed and restart allows you to change the value.
Else do a parameter clear to put everythig to factory defaults
Posted on Aug 04, 2011
Tec sx4 network
Have you checked the port Number.
Tec use port number 8000 and the standard default in windows 9100. Either you change on your printer or in the driver.
Feb 12, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
I have a TEC SX4 printer and im trying to convert the machine to print on thermal labels without a ribbon.. I don't know how to do it! Can anyone help me please
Quite simple.
- Remove the ribbon
- in the support tab of the driver select direct thermal.
- Send a test print to the printer.
It's done
Aug 11, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I can print to a TEC B-SX4 from a windows 2000 print server, but if I set the printer up on a windows 2003 server it goes offline and refuses to print. Same drivers Seagull 7.1.1.
this is due to continuous polling by the driver.
You must disable the bidirectional communication in the tools tag ,driver options, network parameters.
May 11, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
TEC B431-GS10 problem- Print-out in labels are only half
Various possibilities:
- The data cable on the head is not correctly inserted.
- the head is out of order.
- You are printing with a driver with a lower graphic resolution than the head resolution
Mar 31, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
277 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
