Question about Craftsman 55 Torque 158cc 22" Push Lawn Mower ()
Pull cord on my lawnmower is inoperative
When I pull the lawnmower string,the string as I pull free slides with no torque. I'm thinking it might be the nylon pull gear. any advice would be appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Posted on Dec 11, 2012
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
Cant pull string on lawnmower
if motor is lock up pour oil in clinder and work the blade back and forth till it unlocks
Apr 28, 2013 | Craftsman Garden
Lawnmower hit a stump and now can't pull starter cord
you may have bent the crank shaft if it pulls hard and pulls back then remove the flywheel and check the key
Apr 01, 2012 | Garden
Cannot put top up on 1987 allante the latch is locked in and icannot open the latch on the pull down motor
There's a switch ( kinda same shape, color & operation method as your power seat switches) behind driver's seat near the 2 Boot/Top 'release' pull tabs,, it's mounted on the "roof" of the open compartment area behind the seats. Slide your hand along there til you feel it. It recycles the pull-down motor up & down & should release the top. Also try in the trunck, there's 2 hard plastic strings with loops at end,, pull & see if it releases it.
Oct 22, 2010 | 1987 Cadillac Allante
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Won't retract the pull string
The pull cord assembly either has something jammed in there or it's busted. Take the 3 or 4 bolts out that hold in on to the top, and inspect it for damage. If there's nothing in there or it's not damaged it might have just slipped off the spring. Rewind your cord and reinstall it.
Jun 27, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Craftsman 55 Torque 158cc 22" Push Lawn Mower () Logo
295 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
