Cannot format LG usb flash drive UM8 4GB - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
You have to be the computers administrator to change any values on any hard drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
If you need more help with this post a reply
Hope this helps.
Posted on Dec 12, 2012
2 Suggested Answers
JulesPCaut
  • 702 Answers
SOURCE: cant format 400gb usb flash drive
So the disk is recognized? And there is a valid partition on the disk?
What is the error you are getting?
Have a look at this external hard disk troubleshooting, maybe it helps you along.
Jules
Posted on Apr 21, 2009
Phillips dvd player recognizes usb flash drive but wont open it
might need to format the flash drive to the phillips dvd player. make sure you back up whats on the flash drive first. plug into dvd and format it. the player should ask you if you want to format flash drive. because when you format the flash drive it will erase all data on it. then reload the data back on the flash drive. try again
Apr 17, 2014 | LG DN898 DVD Player
How to use usb?
you can play video or mp3 in usb input in your LCD TV , using usb flash drive
be sure the video you put in your flash drive is in AVI or mpeg format.
Aug 27, 2011 | LG 42LC2D 42 in. LCD HDTV
How do I reformat it?
To format a USB Flash Drive, follow the steps below for your OS:
A. Windows PC
1. Power on your computer. 2. Insert the USB flash drive. 3. Click on the "Start" menu and click on "My Computer". 4. Right-click the drive letter that corresponds to your USB flash drive. 5. Select "Format" from the context-menu. 6. A new window will open, input the following information in the correct fields:
File System: FAT32 Volume Label: "Give your USB drive a title" (optional)
7. Check the "Quick Format" checkbox. 8. Click "Start" 9. Upon completion, your USB flash drive will be formatted.
B. Mac OS
1. Power on your computer. 2. Insert the USB flash drive. 3. Double-click on your Macintosh HD. 4. Double-click on the "Applications" folder. 5. Double-click on the "Utilities" folder. 6. Double-click on the "Disk Utility" application. 7. The program will open, select your device from the left-hand pane. 8. Click on "Erase" on the main page. 9. Input the following information in the correct fields:
Format: MS-DOS Label: "Give your USB flash drive a title" (optional)
10. Click on the "Erase" button. 11. Upon completion, your USB flash drive will be formatted.
Aug 15, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
I cannot format my ImageMate USB 2.0 Reader/Writer. It is impossible on two computers. The software program is downloaded but on Computer Manager it does not appear. I have Vista.
You do not need any special software to format a USB/flash drive.
Open My Computer and right-click on the icon for the USB drive. One of the options should be "format", which allows you to format the USB/flash drive
Mar 27, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to my flash format
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format flash
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 06, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I plugged my LG USB flashdrive into my laptop last night and laptop said that there was a USB malfunction. I had just used the flashdrive on a desktop. The flashdrive does not light up either. Is the...
Try the flash drive in another computer, if it works then backup your data.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 22, 2009 | Electronics - Others
Computer crashed while USB was inserted. USB will no longer open.
Scan you pendrive for Virus from another computer who has effective antivirus program & it have latest Update.
Norton is my trusted.
Thanks.
Oct 06, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
My Lg 1G USB Flash drive will not show content
go to run
Change To ur pendrive directory
type
format/q
click enter
It will work. thanks.....
Aug 02, 2009 | LG Computers & Internet
TDK usb flash drive 8GB can not hold more than 5GB
2. Format Flash Drive
Mar 15, 2009 | TDK (MF2HD50PK) (50 Pack) (TDKMF2HD50PK)...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
