Question about Apple iPod nano
The buttons on my ipod is not working
The buttons on my ipod nano stoped working not even the wheel works
  • 502 Answers
The wheel will most likely need to be replaced, there is an ipod nano repair guide if you feel capable of doing this yourself.
Posted on May 04, 2009
    Problem Solver:
  • 9 Answers
Connect it to your ocm'uter and restore it. If you want to know more about it look it up on http://www.apple.com/support/.
Posted on Feb 15, 2009
My ipod nano is not working...i just connect it 2 the charger nd when i just removed the charger after charging......it just fall down on carpet.............................nd i have use ipod many times...
Have you tried to reset it? If you own the new iPod Nano, you will know that it does not have the click wheel anymore.
What you need to do here is: Press the Sleep/Wake button and the Volume Down button simultaneously till the Apple logo appears on the screen.
You may need to try the procedure a few more times before it works, and you can even try connecting it to a computer and then hard resetting it if the instructions still do not work.
Feb 28, 2011 | Apple iPod nano
I was on the bus and my ipod nano just stoped working
try reseting the ipod
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Oct 28, 2009 | Apple iPod nano
Ipod nano 8GB doesn`t work
Hold down the middle button and the top of the scroll wheel until you see the apple symbol. Keep holding the middle button then hold down the bottom of the scroll wheel. This will reset the iPod so that it will work. If the scroll wheel is still not working, take it to the place you purchased it or if it is in the area, find a local Apple Store and take it to them. They will be able to assist as well.
Oct 27, 2009 | Apple iPod nano
Center button and click wheel not working on my ipod nano
Yes, well the exact thing it happening to me. What you could do and see if it works is this: Turn the Screen Lock on, off, and hold the center button and the Menu button. This will hard reset the iPod and use the origonal settings from when you first got your iPod. The second Tip: Take off all of the software, songs, games, ect. in iTunes and reset ALL the settings in iTunes. If this doesn't doesnt work (which it should), your iPod is broken and you need a new click wheel or center button.
Mar 27, 2009 | Apple iPod nano
IPod 8G Nano completely doesnt work.
ResetTo reset your iPod nano:
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 16, 2009 | Apple iPod nano
Ipod nano (4GB) stuck on pause
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Mar 29, 2008 | Apple iPod nano
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
My ipod 5.5 gen video wont sync with itunes on my laptop and only sometimes charges. can anybody help please. its be a present for my ma (mother) for christmas
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 07, 2007 | Apple iPod MA446LL/A MP3 Player
Apple ipod
  • iPod classic
  • iPod nano
  • iPod mini
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Frozen ipod
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 02, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
