Don't know default password and want to change it?
When setting up I made a mistake and wanted to go back to set password. It wouldn't let me go back, just started setup again. How do I get the default password and how do \I change it.
  • 2,878 Answers
Most home wireless routers have a reset option on the back. It may be just a small pin hole, or small button. Hold it in till the router cycles. This will clear all custom settings.
Posted on Dec 07, 2012
peglegcards
  • 89 Answers
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
  • 20 Answers
SOURCE: Default Password
the default password for your westell 327 is username: admin and password: password, the admin admin combination is what usually isp providers such as verizon tells you to put in after configuring it for the first time. 192.168.1.1 is the url add for you to be able to access your westell 327. after accessing your modem you can find the WEP key below the modem, after enabling the security of your network the WEP kep is your default security password
Posted on Dec 20, 2008
virtualhost
  • 2185 Answers
SOURCE: default login & password
You can try the following passwords in this link:
http://cirt.net/passwords?vendor=SMC
Posted on Aug 03, 2009
  • 56 Answers
SOURCE: Change of current belkin N150 password.
from the control panel update firmware to latest http://en-us-support.belkin.com/app/answers/detail/a_id/526/kw/n150/r_id/166
There ware a bug similar to this in the previous firmware version. Let me know if it works. Cheers...
Posted on Sep 14, 2009
T3KK
  • 171 Answers
SOURCE: the default password isnt correct, cant log in. I
According to SMC the default password which is case sensitive is: smcadmin you enter that into the SMC web interface found by typing 192.168.2.1 into Internet Explorer's address bar.
The full manual is here,a nd their support site is here
If this helped you then please help me and vote, thank you
Posted on Oct 12, 2009
How can set my power mac g4 up so as that i'm the owner ....and why can't i download programs,or change my os default broweser
Hi.
I assume that you didn't get any disks with it either. Taking full control without disks is tricky, however you can take majority control - as long as you know the admin password.
Open system preferences (under the Apple menu) and select USERS.
You need to add a new user and to do that you have to unlock the padlock at the bottom-left of the panel that opens up. To unlock the padlock you need the admin password.
Assuming you have it, click the padlock - endter the password and then you can add a new user. Make sure you set it so that the new user can ADMINISTER THIS COMPUTER. Create a new password for the new user. Then underneath the name of the original user you will have the name of the new user and in smaller letters underneath each name you should see "Admin" If you don't see admin under the new user go back and check the Administer bit - NOT Standard User.
If everything is OK so far, look just above the pad;lock and you should see a small penel saying "LOG-IN OPTIONS". Click there and change the auto log-on to the new user name. Now close the windows (red button) and go back to the Apple Menu and select "RESTART"
When the Mac retarts it should come up with a completely different desktop and very few icons. Go back to the USERS control panel and go through the same routine we just used to add the new user but this time delete the original user.
You, the new user, are now in charge. You can download, install and do anything you want but the computer may still appear on a network as "Old user's Co,mputer"
To change the default browser, open Safari, go to Safari preferences and change the setting there. It's an odditty that Apple put the setting there - but there's nothing wrong with Safari as the default.
If you don;t know that Admin password you will need an Installation CD/DVD in order to change it.
Jan 16, 2012 | Computers & Internet
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Cant change router password,dont know how
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 25, 2011 | D-Link DI 514 Wireless Router (DI-514)
I loaned my Dell Inspiron 1501 laptop to my niece and she put a password on bios! I don't know what she was into bios for anyway! I called Dell and they wanted me to spend $69.00 to re-new warranty!...
You may be able to reset the BIOS back to the defaults (including BIOS password) by removing the CMOS battery for 20 mins. Insert the CMOS battery back and go into the BIOS conciguration and set the Date & Time etc.
Aug 22, 2011 | Computers & Internet
A few weeks ago, one of my daughters friends changed my routers username and password, can you help me to find out how they managed to do this please many thanks mrs t holder
If you don't know the IP address of the router, you can open Windows Explorer, click 'Network', and then double-click your router. You'll be redirected to a webpage where you must put in a username and password. If THIS is the username/password she changed, the only way you can change it back without knowing what she changed it to is by resetting the router.This is usually done by pressing a small button near the back. If she changed the password that other computers use to CONNECT to the router (i.e. wireless), then you'll put in your username and password- the default is 'admin' and 'admin', unless you changed it- and from there you can enter the wireless settings to change the password back.
Aug 03, 2011 | Computers & Internet
I have my wii all set up except for the internet. a guy came out & fixed my wireless but now its asking fr a password & i dont know what that would be... i thought maybe on the back of my router...
If it's a Linksys wireless router, then the default password is "admin" in small letters (no caps). Don't worry about the username, it won't require it, until you get into the settings. If it's a Belkin, then Google: Belkin default password, and it will then give you a list of default passwords, depending on your model type. Good luck.
Jul 05, 2011 | Computers & Internet
I can't remember my password and i don't know how to use it
There should be a small pin-hole on the back of the router, maybe even labeled RESET.
Pressing this once will simply reboot the router, holding it down for over 10 seconds will revert the router to it's default settings.
The default password for this router is:
Username:
admin
Password:
password
Note: You'll have to reconfigure any and all settings as they will have been erased.
May 31, 2011 | NetGear WGR614 Wireless Router
Someone changed my password
If someone changed your password and you don't know the password, go to "System Settings">"Restore Default Settings"
This doesn't delete anything from your memory stick.
May 31, 2011 | Sony PlayStation Portable (PSP) Console
How to add internet settings(APN) for Samsung Behold 2 T939
or anyone wanting to know how to change their APN settings for future reference here it is:
on the keypad type *#87927# and wait until the APN setting pops up. click the APN available.
then change these settings.
name : t-mobile us 310 260 ----> name : simple
APN : epc.tmobile.com ----> APN : simple
proxy : not set ----> proxy : 216.155.165.050
port : not set ----> port : 8080
username <leave blank>
password <leave blank>
server <leave blank>
mmsc <don't change>
mms proxy : not set ----> mms proxy : 216.155.165.050
mms port : not set ----> mms port : 8080
mcc <don't change>
mnc <don't change>
apn type <don't change>
authentification type <don't change>
after that just back out and give it a few minutes. as long as you have the data plan your 3g icon should show up ready to go.
Aug 30, 2010 | Samsung Behold II SGH-t939 Smartphone
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
