Model no. EDD2X36FA2 owner's manual
Water dripping from bottom front opening
emissionwiz
  • 75822 Answers
SOURCE: WATER DRIPPING FROM BOTTOM PULLEY AROUND RUBBER GASKET
u have a leaking water pump. the water is running down to the pulley from the pump.
Posted on Feb 24, 2009
woodchuck789
  • 4059 Answers
SOURCE: ice buildup in freezer drip pan and water overflow
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
arikrom
  • 528 Answers
SOURCE: Model PTB1953GRO Maytag Refrigerator-Water drips into
you might need to open the freezer wall and clean the drain hole.. it might be cluge... very EZ :)
take all out even the ice maker unit
take back wall out and see if the drain is cluge with ice or something...clean it and out it all back
Posted on Dec 31, 2009
  • 401 Answers
SOURCE: water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
Posted on Jan 26, 2010
SOURCE: How do you open GE washer model WJRE5550H1WW?
on the front panel under the lid/top piece are two clips use a screw driver to push trawards machine and it will bring front panel towards you and unhinge piece wala! all exposed
Posted on Jun 23, 2010
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our portable LG LP0910WNR is dripping water out of the bottom. The drain plug and cap are in place and not leaking.
This is caused by 2 things. The most prevalent is condensation dripping from the cooling coils. Usually this occurs, because the coils are dirty and need to be cleaned.
The second cause, is that one of the drain tubes (usually the one from the top tank to to bottom tank) is either partially clogged or has come loose from it's connection.
In either case, some dismantling of the units outer cabinet will need to be removed to check and service it. Consult your Owner's Manual concerning removing the outer cabinet.
I hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Heating & Cooling
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a kenmore portable air conditioner. It was given to me so I don't have much info on it. When we use it we have water on the floor after we shut it off. We have ruined the rug . We replaced the...
It from all you said, it sounds like it's condensation dripping from the cooling coils. They are probably dirty and therefore the condensation is not evaporating like it should. Also, the air intake filter may be dirty or clogged.
Since you don't have an owner's manual, locate the model number of your unit and then go online to Sears Parts Central. Armed with the model number you will be able to locate the Owner's Manual and download and print it for future reference. It alone, will prove invaluable.
Hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Heating & Cooling
I have water dripping from my Kenmore Air Conditioner Model #58074055400. I have misplaced the manual so I don't know what the problem might be. Can you help me or tell me where I can get a hold of...
It's suppose to drip water, just tilt the AC a little downward on the outside, so that it drips outside. The water is condensation that's being removed from you room's air... it's called dehumidification... it's a good think for the Summer.
Jul 20, 2011 | Heating & Cooling
Hello there, We have mold which is hard to remove in the liner of our loader and it also drips down the front of the washer when we have ran it. Do you any advice for removal of mold and to stop the...
Hi Clare. Yours is a common complaint, but easily remedied. In your owners manual, you will find that it is recommended to run the "sanitize" cycle every 30 days. This will kill any mold or mildew inside the machine, and keep it from smelling inside. If you havent been doing this, it will be a little harder to get it clean. The sanitize cycle heats the water to 185 degrees ( approx.) My advice would be to run a sanitize cycle once a week for the next month. Put a cup of bleach in the detergent dispenser each time you run the sanitize cycle for the next 4 times ( without clothing inside). Also, leave the door open overnight after completing your wash. This will allow the internal wash drum to dry out and eliminate any chance of mold or mildew inside. When you see a drip down the front of the machine, it is usually lint or hair stuck to the bottom of the glass door where the seal contacts the bottom of the door. Keep this area clean and lint free and your leaking should stop.
Feb 21, 2011 | Miele W 4800 Front Load Washer
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
How do you open GE washer model WJRE5550H1WW? When my washer adds water, some of the water drips down towards the bottom of the machine.
Oct 01, 2009 | GE Washing Machines
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
