Question about Hotpoint Refrigerators
My ice maker won't dump the ice
The ice cubes are frozen. they will not dump out
SOURCE: roper ice maker
My ice maker was making ice just two days ago after being off for a while. I am a new tenant. I made one basket full of ice, which I dumped to make sure the system and water was flushed thoroughly. Now the ice is just stuck there, you can see the cubes but they aren't going anyway. I try to gently force them out, but no way, they aren't budging! So, how do I eliminate this problem?
Posted on Oct 06, 2008
HVACRH20
  • 237 Answers
SOURCE: Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Posted on Nov 09, 2006
Richie_asg1
  • 1036 Answers
SOURCE: ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Posted on Jun 11, 2008
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
Help! Our ice cubes are frozen but not dumping and our tray is filling up with water fitting a solid sheet of ice. Can anyone help? Thanks
Hello;
My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Feb 27, 2016 | Liebherr Refrigerators
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
How do I un freeze the ice cube maker?
The heater on the bottom of the ice maker has failed and you will need to replace the ice maker mold. Here is a link to the part.
If you would rather replace the ice maker, here is that part.
Oct 19, 2012 | Kenmore Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker will not make ice
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Refrigerators Logo
251 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
