Question about Toshiba Satellite L875D-S7230 Laptop
Keyboard with normal working f-keys
I use the f-keys all the time can one get a normal keyboard on this laptop ?
    Sergeant:
    Champion:
  • 272 Answers
You can always buy an USB keyboard.So,why need to worry about keyboard in your desired laptop.
Posted on Dec 14, 2012
WHen using the shift key to type the at sign or the esclamation mark etc it does numbers
Is this the only problem with the keyboard not getting uppercase to work ?
While Acer laptops are built to be used on the go, they are not indestructible. An accidental drop or even normal wear and tear over an extended period of time can cause the laptop keys to become dislodged and fall out. Debris can also build up inside the keys and make them stick or stop working. Fixing the keys on your Acer laptop is a quick process that does not require taking the unit to a professional repair shop.
Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop. Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole. Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole. Set the key back onto the plastic clip. Push the key down until it clicks into place. Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen. Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop. Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air. Reassemble the keyboard, LED indicator strip and battery.
Acer aspire keyboard removal http://www.cyfinity.com/2008/07/acer-aspire-5315-keyboard-removal/
Mar 01, 2013 | Acer Aspire Computers & Internet
How do I open up my easy note Packard bell lap top to see why they keyboard is not working? And is there a way to test the keyboard before buying a new one?
yes, There are screws on the back side of your laptop that do not remove but do loosen and release the keyboard. release the keyboard and gentely get keyboard to pop up and reseat connection to the keyboard to the main board. normally on laptops, keyboardsare able to lift where the f keys are and then slide in the direction of space bar to f keys. this needs to be done slowly with ease
if this helps please take time to rate
Feb 01, 2013 | Computers & Internet
Keyboard does not work at all.
1.Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.
2.Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.
3.Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
4.Set the key back onto the plastic clip. Push the key down until it clicks into place.
5.Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.
6.Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.
7.Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.
8.Reassemble the keyboard, LED indicator strip and battery.
Sep 07, 2011 | Acer Computers & Internet
My keyboard only works when it wants to, i thought it was a virus but my laptop is now virus free and my keyboard still does not work properly, sometimes does not work at all sometime the number two holds...
If you have a sticky key that you know of you may have a couple that you haven't noticed. The number 2 key sticking usually means something was spilled on it at one time.If nothing is spilled you will only see the keys at the sides act up and usually the longer or larger ones. These act up from not hitting them straight but at an angle.
The next time it does this try thumping the keyboard to jar stuck keys loose. The key may look ok but is stuck just enough to do this. You just need to flick a finger at the keyboard to knock them loose. You may have to do this a few times before it dislodges the offender. On a normal keyboard you flip it over and knock on the back like knocking on a door to do this. On a laptop you can't hit it as hard.
If the keyboard keeps doing this your option is to replace it. Depending on the make and model a new laptop keyboard is about $45-$75 and is installed in a few minutes.
Sep 02, 2011 | MSI Computers & Internet
My keys of my keyboard aren't working, what can i do to solve my problem? ( just especific keys aren't working )
The keyboard may be faulty or the keyboard chip on the motherboard may be faulty.
To determine id it is a motherboard problem, connect an USB keyboard into ythe laptop's USB port and if the keyboard works correctly then the laptop's keyboard needs to be replaced.
A replacement keyboard may be available from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jul 15, 2011 | Compaq Presario Notebook
ACER ASPIRE laptop PgUbp key came off.
Unless I'm missing something, just put the key back where it belongs. Push down hard, and it'll snap back into its place. If this doesn't work, check the underside of the key. If you see broken plastic, you'll probably have to find a new key. Acer laptops seem to have a problem with keys coming out and breaking (just look at the number of times this question has been asked!)
hope this helps
Apr 06, 2011 | Acer 90.46907.001 Keyboard
Some of the keys in my lenovo laptop 3000 v200 is not working the way it should. Some keys like ''t'' when press comes out like ''tb'' and y as ''yn''. Some keys won't function if I don't press it hard...
The keyboard controller maybe faulty. Connect a PS2 or USB keyboard to see if it functions correctly. If the external keyboard works normally then the laptop keyboard is faulty and can be replaced.
If the external keyboards do not work normally then it is a motherboard problem.
Dec 02, 2009 | Lenovo 3000 V200 Notebook
Keyboard stuck on fn
I found this on another site, and it worked on my Vostro 1510:
Try pressing shift + numlock (Scrolllock in blue) to toggle the Fn feature.
Normal numlock comes on, so press it again by itself to turn that off.
Apr 24, 2009 | Dell Vostro 1510 Laptop
Laptop keyboard on lifebook c, replace or fix
It looks like you answered your own question - you really can't fix a laptop keyboard, but you can replace them. (or you can use an external keyboard)
Now is your problem:?
Letters qwert, asdfg, zxcvbn work OK but uiop displays as 456/ jkl displays as 123 and m displays as 0. Other keys also do not display correctly. Or holding the function key down at the same time as the problem keys ?
Then the solution is:
The problem was caused by accidentally pressing the num lock key. Once pressed, it remains locked even after a reboot. Pressing again returns the keyboard to normal.
Jul 22, 2008 | Computers & Internet
Keyboard
uninstall the driver and reinstall it.
goto:
start> control panel > admin settings> computer managment> device managment> human interface (keyboard joystick mouse etc...)
only uninstall the keyboard but realise when it is un installed it wont work! untill you reboot the computer and reinstall it.
good luck
Oct 29, 2007 | Toshiba Satellite M30X-S181ST Laptop
Toshiba Satellite L875D-S7230 Laptop Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
