Lose signal when i change channels - Computers & Internet
  • 7,627 Answers
Yes, Reboot you computer.
Posted on Dec 07, 2012
LG 32LH3000 is turning off when changing the channel
Do you have a box of some sort in line to the set for signal?
Dec 12, 2012 | LG 32LH3000 32" HDTV-Ready LCD TV
Losing signal 20 metrers away
FIrst check for any type of RF( radio Frequency) intererence in your area. Next, log into the router using the default gateway ip address and change the signal channel. The signal channel is locate under channel and ssid into the Belkin's router control panel
Jun 06, 2011 | Belkin (F6D42304) Wireless Router
Suddenly losing wireless signal then getting it back later.
Is it close to a microwave, or a cordless phone?
Does it only lose signal when the phone rings, or you are using the microwave?
Try moving it further away from either of these, and change your phones channel.
Hope that helps,
Forest
Feb 18, 2011 | ASUS (wl500g) Wireless Router
Dynex TV losing favorite channels
Try changing the batteries in your remote. If the batteries are weak they may not be sending strong enough signals to the TV thus sending different signals than you meant.
Jan 24, 2010 | Dynex DX-L19-10A LCD TV
Belkin wirless router lose signal after approx. 30
Check the wireless channel on the router.
Is it properly set ?
you can try changing the wireless channel on the router.
Or if that doesn't work then you can try to upgrade the firmware of the router.
for this you will need to open the set up interface of the router.
Click Here to know more about routers
Oct 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Usb 2wireless adapter keep losing sigal
If your computer keeps losing the signal, you need to either change the wireless channel or boost your wireless power on your router. Sometimes even a combination of both is needed so you stop losing signal.
Feb 19, 2009 | 2wire 1000-200004-000 Network Adapter
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Lose signal
While some loss is expected. You can change channels. 1-6-11 are the best for cutting signal loss because they do not overlap.. 2.4GHz device in operation, like a cordless phone or microwave oven can cause signal loss. Metal in walls, electrical devices and wires can also cause loss.
Jan 03, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Losing net signal
Hi you need to go into internet explorer, in where you would type www.ebay.com for example you type 192.168.1.1 im sure thats correct one for your router, but if you know the routers ip address just put it in, hit enter
a menu will appear asking for username and password
usually - admin , password - password
or
admin ,admin
you will find correct setting in manual if you still have it,
once you get in, click on wireless settings, in there you can change the wireless channel quite easilly..
Happy New Year
John
Jan 01, 2008 | Zyxel Prestige 660H Router
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
