Question about Frigidaire GLTF2940ES Front Load Washer
The washer starts ,but stops by thevdraing cycle.Did press start and pause cancelknop simultaneously and it shows E 23 as errorcode ,which means that the pump relay on controleboard failed.Do I have to change the whole board,or is there some other problem that can be fixed ,instead of changing the board? I did press cancel and kept it pressed a while .After that I started the washer normaly and there is a sound from the pump ,but that s all.It wouldn t drain the water nor spin..is there away to fix this?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
E23 = Drain pump relay on control board failedReplace control board.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Dec 08, 2012
catriver
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
SOURCE: Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
SOURCE: Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Posted on Aug 26, 2009
SOURCE: Electrolux EWX 14440 W Washer will not start
This sounds like what I am having. Machine tumbles but does not rinse. Some postings say this is the door lock problem. Google "Fridigdaire washer will not Spin" and page down to read solutions.
Posted on Oct 26, 2009
My whirlpool cabrio washer made a loud pop and then showed a f3e1 error code. what does that mean? what should I do?
this is a combo code i had on my washer as well ..... its the pressure switch under the tub that detects the weight of the water to know how much is in the tub .... the code means there is a problem with the pressure switch and there is no signal to tell the computer how much water is in the tub ......... if you ever notice the washer hasn't spun enough of the water out this is a sign i had 2 weeks before the code appeared on my washer .... http://producthelp.whirlpool.com/Troubleshooting_Guides/Troubleshooting_for_Top_Load_HE_Washers_(Electronic_Control)/Error_Codes/F%23_E%23_or_F%23%23/F3_E1_Error_code_for_top_load_washers
Feb 14, 2015 | Whirlpool WHRLPAIR1WHITE WTW8500BW Cabrio...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
I changedthe controle board!but now when I start the washerthe water doesn t run. i pressed the press start and cancelknop simultaneously and it shows E5e which meansthat there is a communicationprob
Hello Ivan Kelly - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. If the wiring is bad, it has to be corrected. However if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Dec 09, 2012 | Frigidaire GLTF2940ES Front Load Washer
Pause lock keep showing up on screen
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
What wrong when washer machince stop in the middle of cycle and leaving water inside make humming noise read err
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
you may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Nov 28, 2011 | Frigidaire Washing Machines
Machince stop in middle of cycle leaving water inside make humming noise
Wait 5 seconds
Nov 28, 2011 | Frigidaire GLTF2940ES Front Load Washer
The washer stops half way through all cycles and displays "oL" .
Error oL means overload.
If the "oL" error code appears, the washer has been filled with a load that is too large for its capacity, causing it to drain.
*Remove some items from the washer and add more detergent since the previous amount will have drained with the water.
*Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle.
If Pause/Cancel does not work:
*Unplug washer or disconnect power for one minute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Hope this helps.. :)
Jun 08, 2011 | Washing Machines
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service
Jul 18, 2008 | Whirlpool Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
289 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
