Ovens Logo
Posted on Sep 10, 2017
Do we have a fix for this ? Got a new Jenn-Air JMW2427WS. The microwave does not shut off by itself after the set time. The fan,light and the turntable keeps running until someone goes and opens the door or push the cancel button. Anyway around this. I want the microwave to stop automatically after its job. Shouldn't that be a normal feature for any microwave.
Ken Johnston
Level 1:
New Friend:
  • Contributor 56 Answers
  • Posted on Sep 10, 2017
Ken Johnston
Contributor
Level 1:
New Friend:
Answers
56
Questions
Helped
8764
Points
79
There is a logic board defect as it should stop automatically
Call the mfg or repair it
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Feb 19, 2008
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
A
Anonymous
  • Posted on Apr 26, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Anonymous
  • Posted on Jan 04, 2009
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
tzweeb
Tom Zwiebel
  • 318 Answers
  • Posted on Jan 22, 2009
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Anonymous
  • 6784 Answers
  • Posted on Apr 16, 2009
SOURCE: Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Jenn Air JJW9630. Why doesn't it start cleaning cycle?
After 20 years of faithful service, your Jenn Air deserves retirement.
Sep 10, 2021 • Ovens
Jenn-Air model WW27430P. After heating to set temperature and baking for 8 to 10 minutes, why does it shut off?
It's faulty and in some sort of self protect mode. You need a service call or you can try some of the fixes here.
FIXED - WW2780 Jenn-air oven keeps shutting off ...
www.applianceblog.com > mainforums > threads > ww...
Feb 15, 2012 - Hi.... I have a Jenn-air oven model WW2780 that keeps shutting off after being turned on, almost always during the preheat. From what I have ... Missing: WW27430P ‎' Must include: WW27430P
Jenn Air Range Stove Oven - Oven Won't Turn Off - Repair ...
www.repairclinic.com > RepairHelp > Jenn-Air-Oven-...
Here are the most common reasons your Jenn Air oven won't turn off - and the ... Enter model number to search for the required part specific to your product.
HOW-TO: Jenn-Air Oven WW27430P Door won't close
www.appliancepartspros.com > repair-help > ww27430...
Door won't close is the most common symptom for Jenn-Air WW27430P. ... I have a Jennair jjw9630cas double wall oven, and after a few years I noticed that the light would not go out, first in the bottom ... Door pulls shut and li8ght stays off.
HOW-TO: Jenn-Air Oven WW27430P Won't start or doesn't start
How to Replace Oven Temperature Sensor Kit for Jenn-Air WW27430P Won't start # ... Jenn Air stove JDS9860CDB00 error code 1d11 oven not shutting off. ... Very easy on this and other models with this sensor-- just two screws holding it in ... Rating: 5 · ‎123 reviews
Nov 17, 2020 • Ovens
Yesterday I "self-cleaned" by oven.
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
1helpful
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 • Ovens
1helpful
5answers
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jenn air combo wall oven/microwave
2answers
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
