Question about Whirlpool Dryers
LER8648LWD outlet got wet do i have a power fuse to replace?
    Problem Solver:
  • 7 Answers
Check voltage at dryer plugin. If no voltage go to breaker panel and reset breaker by making sure you move breaker switch fully to the off position and then you will feel tension as you turn breaker back on.If it kicks back off you will need to turn off main breaker and open dryer outlet and probably clean it out.
Posted on Dec 07, 2012
05 honda accord have no power in the cigarette lighter and power outlet
Well... because there can be several things that cause this issue, you want to start with the process of elimitation. Is your car powered on when you try and use the outlet? Most veichels will not allow power to the outlets when powered off.
Observe the outlet and remove any foreign objects from the outlet, there may be a fuse or metal from a broken acessory stuck in the outlet.
Start by pluging something that works into the outlet (like a cell phone charger wit an led to indicate power) locate your veichels fuse box as per instruction of the cars manual. Remove fuse cover and locate the fuse location of the outlet in question, often labeled power or accessory. Observe the ratings of the fuse and be prepared to replace it if need be (it's good to keep common spare fuse for your veichel in your glove,trunk,ect). Remove the fuse and use a fuse tester to test the fuse or look to observe if the fuse is blown, if so replace the fuse, if the led on the charger plugged into the outlet emit's light then you have solved your problem, and if not stop work and call a mechanic or post another question. There are other things you could do but nothing that I would advise without you asking.
good luck and thanks
Questions? Just ask! Mr.Mike
Nov 17, 2015 | Honda Cars & Trucks
2012 Hyundai Sonata only one 12v power outlet working how to fix the other outlet?
Check the fuse in the instrument panel junction box, left side of dash panel. Tan color box, power outlet 1 or 2 15amp fuse.
Feb 01, 2015 | Hyundai Cars & Trucks
Cigarette lighter outlet not working
1) many vehicles has various fuses for outlet power
2) you must go to the fuse box and check all fuses if are o.k see the diagram attached and test with a VOM
3) if the fuses are o.k you must dissasembly the dashboard, for to test the outlet for +12vdc with VOM, or another outlet power, and replace the labor is medium complicated, but you do not have a choice.Use carefully and remember to unppluged the terminal + of main battery.
Unless you want to go to the repair shop.
Jul 25, 2012 | 2004 Toyota Camry
Garmin won't start
have you dropped it recently? gotten it wet? any kind of damages?
also you could have a bad power outlet in your car that isn't giving your gps enough juice to start up. that happened to me and i just plugged it into a different outlet and it worked fine. might check your fuses to your outlets also in your car.
could also try plugging it into your computer to try and update the software.
Feb 28, 2011 | Garmin Nuvi 265W GPS Receiver
How do replace heating element in dryer
Instructions
Things You'll Need:
* Volt meter
* Clean cloths
* Waste bin
* Replacement fuse (optional)
1. Secure the power cord in the Frigidaire dryer as well as the power outlet if the dryer does not start. Replace the fuse or reset the circuit breaker if necessary.
2. Check the fuse if there is power but no heat, as dryers need two fuses in order to operate properly. Replace the fuse if necessary. Select heated cycles if items are wet and cold after drying.
3. Open the dryer door and slide out the lint screen if the dryer seems to be taking a long time to operate. Clean off the lint and return the lint screen to the unit. Use a volt meter to check the power outlet for proper electricity, which should be 240 volts or more. Clean the exhaust hood outside the home and straighten the exhaust vent if bent.
4. Keep the load size medium and distribute pieces evenly inside the drum if items are wrinkled or damp. Increase drying time or temperature as necessary.
5. Check pockets for hard objects before putting pieces in the dryer, as items can create scratches or chips inside the drum and cause a clinking noise during use.
6. Contact Frigidaire for assistance if the problem continues.
Feb 24, 2011 | Frigidaire Electric Dryer
Fuses seem to be in tact but power outlet doesn't work. What next?
if the fuse is good, then remove the outlet and check for power and ground at the outlet. If they are both there, then you need to replace the outlet. Also sometimes the outlet won't get grounded off of the casing so it won't work, which you also need to replace the outlet. nine out of ten times you replace the outlet.
Oct 08, 2009 | 2008 Lexus Rx 330
Washer will not turn on. i have checked outlet
Some machines have a limiting fuse in the wiring. this has possibly blown. replace it and retry. Normally the fuse is found in the panel on top. It will be in a fuse cartridge. If when you do find it and replace it,and it blows again, your board will be the problem. .
Sep 21, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Power Outlet Fuse
it must be shorting out,dont put a bigger fuse than you have because youre going to have an electrical fire,instead check the wires to the outlet if ok just replace the outlet
Jul 07, 2008 | 2002 Buick LeSabre
Dryers Logo
64 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
