Question about Aastra Telecom Aastra 9110 Single Line Corded Telephone (AASTRA9110)
Aastra 9110 message light doesn't light
Installed an Aastra 9110 connected to an Avaya CM6.2. The toggle switch has been moved to the Avaya 120V setting (there isn't an Avaya 24v setting) and the message light will not turn on. Has anyone else had this issue? If so, how did you resolve it?
    New Friend:
Were you able to get this working? hat did you have to do?
Posted on Sep 16, 2014
120v 240v
On the back of the computer where the power plug goes, should be a toggle switch, change it to 120V.
Jun 29, 2013 | Computers & Internet
Aastra 8004 Message light constantly on
Sent yourself a message from another phone then delete it with 3 3 7. That should do it
Aug 08, 2012 | Aastra Telecom Aastra 8004 Basic Telephone...
What's your problem? The side view mirrors on my 2002 Chevy Tahoe do not adjust using the toggle located on the driver side door panel.
The switch is a contact type. When you move the switch it complete the circuit by connect the two contacts points. After some time the switches wear out simply replace the switch.
Oct 23, 2017 | 2002 Chevrolet Tahoe
I can't remember my password to access messages on my M6320
Your provider will have to reset it for you. They may charge you for it though. That is the only way
Feb 28, 2012 | Aastra Telecom Aastra M6320 Single Line...
How to turn on the wireless switch on my IBM T42
There isn't a switch on the T42. (I'm using one to write this). the Function (Fn) key toggles the adapters but only if the correct utility is loaded. That is on the lenovo site called 1qkcb9ww or 8jvu12ww. Not sure which controls those features. If Fn+F5 doesn't do it...
You otherwise usually get that message when there is a network adapter conflict and sometimes if the driver has become inactive which it does not too often. Try first disabling any other network adapters like Ethernet and maybe even the infrared network adapter though I doubt that could be it. Mine is disabled anyway. Do this in 'Network connections' from control panel for the Ethernet or with Device manager (Systems>hardware>device manager) if you never use a wired connection. If that doesn't help try reinstalling the drivers from the Lenovo site.
Andrew L.
Nov 22, 2011 | IBM ThinkPad T42 Notebook
I just installed a Wood 59018 timer, and when i try to turn it on manually, I hear the relay click on and then immediately off (the attached light turns on and off too). That's when the switch is set...
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Jul 09, 2011 | Woods InWall 7 Day Digital Programmable...
How to I forward a number from one phone to another?
If your phone company provides the service, you should have a code to enter. If YOUR telephone switch is doing the forwarding, you will also have a code to enter.
Basically, you enter the code, then dial the number and hang up. To unforward, you dial a similar code, and hang up the phone.
May 06, 2010 | Aastra Telecom Aastra 9110 Single Line...
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Feb 18, 2008 | Aastra Telecom Aastra 9110 Single Line...
Aastra Telecom Aastra 9110 Single Line Corded Telephone (AASTRA9110) Logo
184 people viewed this question
Top Aastra Telecom Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
voyager663rd
ray gallant
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
