Question about OKI B6500 Led Printer
Have to power off oki b6500 to print when in power save mode
Job sits in queu till powered down in power save mode. Intermittent.
  • 8 Answers
SOURCE: oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Posted on Sep 26, 2008
yooperbud
  • 8637 Answers
SOURCE: Oki C5300 Ink Density
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
markzbylut
  • 64 Answers
SOURCE: I have a Oki b6500. Replaced the fuser. How to
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
Posted on May 20, 2010
  • 3 Answers
SOURCE: service error 02
SE 02
: Software Exception
Posted on Sep 22, 2010
SOURCE: OKI B6500 service error 03
hola buenos días tengo una impresora oki B6500 se le cambio el tonner despues del cambio manda el mensaje de tonner bajo que debo de hacer para quiatar el error que marca
Posted on Jan 11, 2011
Why is my printer only printing a black sheet of paper?
Hi it is not the toner but it could be a developing unit or transfer roller.
But since on b6500 the developer unit is changed with the toner it is probably the transfer roler or HV unit.
Regards
Apr 10, 2015 | OKI B6500 Led Printer
Delete print jobs
open print driver and in the status window right click and select cancel print
or when printer is running print job press cancel button
May 20, 2014 | OKI B6500 Led Printer
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
Jan 15, 2014 | OKI B6500 Led Printer
The power button on my hp deskjet 3845 is flashing & not responding to pending print jobs. help
it is possible that the printer as a ink issue or thinks it has a paperjam, another thing that can happen is that the print sent to the printer become corrupt locking the printer in a "i dont know what to do" state.
try to run a test print through the printer using the internal test, this is normmaly done by holding down the power button till the power light blinks it should then spit out a print (do this while unplugged form the computer)
**for full test print instructions refer to user manual)
if the driver has become corrupted it also will send damaged print information to the printer
if the test print works fine than you may need to delete all your queued jobs and then run a WINDOWS TEST PRINT form the driver. if this still does not work reinstall the drivers of the printer
(providing the printer will run an internal print)
Feb 08, 2011 | HP Deskjet 3845 InkJet Printer
Sep 29, 2010 | OKI B6500 Led Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
May 19, 2010 | OKI B6500 Led Printer
How do i cancel a print job on h okidata printer
Click on Start - Printers & Faxes - then double click on your printer.
It will display a list of files that are queued on that printer to be printed, then right click on the print file you want to delete and then click cancel.
Dec 16, 2009 | OKI Office Equipment & Supplies
I cannot delete a print job, it just states that
Part of the print job may be in the printer's memory and part may be in the PC's memory.
Rebooting the printer will remove the portion in the printer, but if there's still some in the PC' sit will just start to "refill" the printer when it comes back online.
Go into your Printers folder (Start > Settings > Printers -or- Start > Printers) to find your HP and open it. Now you're looking at the print queue. If there are any print jobs, there, delete them.
Now reboot your PC and your printer together. Power them both down fully (Start > Shut Down > Shut Down), then power them both up. Make sure they're off and not just in sleep - low power mode. When you're back online, any stuck print jobs should be gone.
Jun 09, 2009 | HP Officejet 5610 Color All-in-One Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
OKI B6500 Led Printer Logo
108 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
