Question about Pitney Bowes C180 Copier
C550 Pitney Bowes Copier
We do not have manual Serial # 8110145 Model C550 showing that we need to call. this #. But they want to change an arm & leg for it. We are a Non- Profit and this copier was donations to us. Please call if you can help.
Martha
The First Tee of Fort Worth
817-420-9370
Fax 817-420-9372
  • Nike Merritt May 11, 2010
    Did you get the manual I sent you?
    Did you get the cd i sent you?
SOURCE: Pitney Bowes Copier - C180 - Error E3
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Posted on Sep 17, 2008
  • 18 Answers
SOURCE: Pitney Bowes C180 copier: what does a U16 code mean?
Develepor unit failure. Did you by any chance remove the Develepor unit? or did you come close to the wire connector located behind the toner bottle if so reconnect it. NOTE ! Before checking any connector make sure the power is off and not plugged into the wall outlet ....Good Luck
Posted on Nov 27, 2008
  • 1297 Answers
SOURCE: pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Posted on Aug 22, 2009
  • 149 Answers
SOURCE: PITNEY BOWES C180 COPIER
Thw wrench means an overdue pm item, usually the web cleaner in the fuser. The machine will shut down after 1000 copies past the copy count due. The count has to be reset by a tech after replacing the web
call 1 800 243 5556
Posted on Feb 24, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I am trying to find a fuser asm for a Pitney Bowes C550
Your Pitney Bowes C550 is made by Minolta, Model EP5000. Precisionroller.com is a good source for parts. Just do your searching by the Minolta EP5000 model and you find anything you need.
Good Luck and Thank You for using Fixya.
Posted on Jun 05, 2010
Instruction manual for pitney bowes copier AD20
I have this manual on my computer. If you send an email to LBrown18062@hotmail.com I will send the manual to you right away. Please put PITNEY 9920 as the subject line. I hope that this will help you out. Lawrence Brown
Oct 21, 2011 | Pitney Bowes C180 Copier
Looking for a manual for AD20 copier Serial # 042100
Oct 21, 2011 | Pitney Bowes Office Equipment & Supplies
I have a Pitney Bowes Model 1630 copier / printer, Message "Printer Jam offline" .No Paper jamed in unit...How can I fix ?
A sensor is probably blocked or a torn piece that cannot be seen is in there. Take a can of air to it. Also turn it off and turn it back on for added measure.
Mar 09, 2011 | Pitney Bowes Office Equipment & Supplies
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
WheatlandServices
Dec 31, 2010 | Pitney Bowes C180 Copier
Jun 05, 2010 | Office Equipment & Supplies
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
Pitney bowes model c400 copier error 0070??
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
79 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
