Question about Samsung Dryers
Replace heat coil dv330 - Samsung Dryers
  • Samsung Master
  • 8,220 Answers
I ran the dryer without the lint screen and am now 'missing' some socks. The dryer makes a rumbling noise. How do I get the socks out and did I break something
you better inspect inside the exhaust vent tubes for the socks. You did not break anything but they might start on fire later. You to take off the back of the dryer to take the vents apart.
Feb 17, 2015 | Samsung DV330AE DV330 Large Capacity...
I filled out a detailed problem on my Samsung dv330 aew on your form on your website and do not see it or do not know how to find it.
Not enough information about problem what is problem ,
You should decscribe problem with clarrity
Dec 08, 2013 | Dryers
Heating coil
No matter if u not findout the inside or outside coil then u can check by multimeter its positive or -ve points
Jun 09, 2013 | Hotpoint Aftermarket Clothes Dryer Heater...
Samsung dv330 dryer. Display comes up, no error codes, door switch seems to be making & breaking since I get a "do" code, timer counts down, no motor or heat. Slight click when you hit the...
Hello Jim,
I'm glad I was able to help you. Hopefully you can return the help regarding my assitance on the chat session for your dryer.
For some reason your accepting my solution has not been recorded although you rated the help as 4 thumbs up...my account shows the solution was rejected.
Perhaps you can log in again and amend the error, as much as I like to help with the chat sessions, it is based on customers honoring the system and us experts providing help on the premise of getting paid.
Thank you.
Regards,
Macmarkus :)
Jul 10, 2011 | Dryers
I have a Kenwood RC-DV330.The battery was disconnected and it is now asking for a password in which i do not know.Is there any way to reset this
I have only the genaral rule, I dont know the particulars.
Kenwood used to have preset passwords as 1234
pressing the stop button ( if you have one ) for 30 seconds.
As i said these are general rules for reseting but I'm not familiar with your model
( buy Yamaha )
Feb 23, 2011 | Kenwood RC-R0720 Remote Control
TUMBLE DRYER NOT HEATING UP
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
Dec 04, 2009 | Dryers
Dryer isn't heating up
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 14, 2009 | Kenmore Dryers
IS IT POSSIBLE TO UPGRADE DDX 6039 TO DDX 7039?
With this post i presume you are on about in dash monitors!
the DDX6039 and DDX7039 will connect in the same way.
however the remotes are different, the 6039 uses remote rc-dv430 and the 7039 uses an rc dv330.
Feb 15, 2008 | Car Audio & Video
Coils don't heat
The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
