Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Oil and gas mixture for jonsered chainsaw - Husqvarna "Chain Saw - 16" Bar, 3 Hp
  • 120 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
dontbother10
  • 2220 Answers
SOURCE: It Won't Start
Read your manual very carefully. I think it is flooded. Read line 3 (cold and warm). read them again. Read 5 in your manual. Most overlook the attempt to start , continue with the choke closed and the saw floods. You have an additional visual indicator, watch the decompression valve, when cold; once it pops turn off the choke. The warm procedure is very close to mine.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If it still will not start return it for a replacement or your money back. Anything you do may render any warranty invalid.
Did you purchase this in a big box store? What is your elevation?
All new saws regardless of maker are set to run extremely lean to meet EPA mandated air quality standards. They are also fitted with a device to restrict richening the carburetor beyond initial factory settings this too required by the EPA. Most big box stores put them on the shelf and sell them to the consumer with no thought of how elevation may impact saw performance or longevity. Homeowners usually are not concerned about changes in the saws performance until it quits operating. This combination results in many destroyed saws and homeowner saws of most brands being called trash!
Find a local chainsaw seller/mechanic. If they pull a saw off the shelf and hand it to you without making some adjustment or minimally ensuring it will run hand it back and leave. You can get this service at a big box store cheaper. Find a different seller/mechanic and try again. A good dealer will help you arrive at a saw that will meet your needs. He will ensure it runs properly and you have an understanding of how to properly operate it. Should a problem arise you have somewhere to go and if you were courteous with your dealer someone in your corner helping you rectify your problem.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 08, 2010
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
  • 27 Answers
SOURCE: I have a Husqvarna 36 air injection gas chainsaw
it usually gives the ratio on the oil container
Posted on Jun 17, 2010
jmgldsmth
  • 1889 Answers
SOURCE: OIl gas mixture ratio?
one small bottle of oil from the auto parts store ( i don't know the oz. size)to one gallon to one gallon of gasoline; mixed well
Posted on Jul 24, 2010
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
What is the gas to oil mixture for a jonsereds 00
www.jonsered.com
download a manual for above link.
Sep 21, 2014 | Garden
Fuel to oil mix for jonsered 490 chainsaw ?
its a 50 - 1 mix of 2 stroke oil to fuel or 2 1/2 ounces of oil to 1 gallon of gas
Apr 03, 2011 | Garden
Fuel mixture ratio
Oil Mix Ratio:
Starting in the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl and Tanaka all started recommending 50:1
  • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen recommend 40:1
  • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil or
  • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Jan 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
HusqvarnaUSA.com
06 1500198
Oil Mix Ratio:
Lou
May 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
What is the mixture of oil and gas
Husqvarna recommends 50:1
Lou
Apr 24, 2010 | Husqvarna Chain Saw 20" Bar
Jonsered 2171 no gas going to carb. Put gas in carb run for few sec's. Blew out fuel filter seems to be fine. Not much use on saw.
the reason is you need to clean out the carb,if they dont get used much the oil/gas mixture turns to a varnish in the small carb ports and fuel can no longer get thru the carb
Mar 28, 2010 | Garden
What gas-oil ratio to use on jonsered 625?
50:1 ratio....Jonsered smokeless is what I would recommend.Ask 5 people what oil to use and you will get 4 different answers.
Nov 17, 2009 | Sport & Outdoor - Others
Need to know gas to oil ratio jonsered 535 chainsaw
50:1 is the mixture for the Jonsered 535. I bought mine new around 1991 and it's been a great saw.
Apr 04, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
20 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
