Computers & Internet Logo
Posted on Jan 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wireless assistant works properly for about 25 mins after switching on the laptop, then it state that the LAn is not connected to the internet anymore, although other computers easily access the net through the same router!
  • chrisgeeuk Feb 01, 2009
    Similar issue here other computers can connect and see but I can not
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Jun 29, 2009
Anonymous
Expert
Level 2:
Answers
60
Questions
0
Helped
30357
Points
110
It's been isolated that the problem is coming from the wireless adapter on your laptop since other pc works fine. Try updating the driver on your wireless adapter and see if that will resolve your intermittent connection.
Won't find internet connection
How is your laptop connected to the Internet, is it by DSL or cable modem via a LAN cable or a wireless router?
Please provide these details plus your laptop make and model. LAN and Wireless card etc. for me to assist you.
1helpful
Wireless lan not working on my acer aspire 4520
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
Instructions:
1.Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
2.Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
3.Select the network you want to connect to and click "Connect."
2helpful
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
2helpful
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
1helpful
I can't find the wireless switch on my Aspire 1691WLMi
The switch is on the right edge in the front of the unit.
Setting up wireless connection
1. Please switch on the wireless LAN using the switch on the front (on the right) of your Aspire one.
2. Click the icon on your system tray and choose the wireless access point you want to connect to. Download the User guide and setup guide from this link: http://www.electronicpulp.net/2009/02/25/10-inch-acer-aspire-one-quick-guide-and-user-manual-now-available-online/ If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
2helpful
Can not turn on wirless capability using Fn & F2 keys
have you tried restarting see if internet picks back up if not try this
control panel
network connections
right click your wireless
if you see enable the click
if not then click repair.
please let me know if this solved if not we'll go to the next step
2answers
Lan wireless connection
identify moel # to better assist. for Toshiba, i own one , the config utility is only needed to search for a wireless first, then it will reset. sounds like you have too many wireless setup installed, go into the internet connection section and see waht wireless setups there are and delete same. you will want a new install.
\MAKE sure if you are using a wired connection hat same is turned OFF when trying to do a wireless.
CGA5722 - Boxed in "A
can you a little bit describe what other device that you are using. maybe access point. Are you using an access point?, or switch?
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
