Question about Onkyo HT-S780 System
SKW-530 I need a schematic for the Onkyo SKW-530 sub-woofer. Any body have one?
  • Tom White Dec 09, 2012
    Ok, I was able to get a schematic for the skw-530. But the schematic doesn't give me what the voltage coming out of the linear transformer that feeds the ciruit board. There a two resistors that are connected to the transformer that get really really hot. the printed circuit board where the transfor connects does say "AC in". My question is what should be the proper voltage to the circuit board?
3 Suggested Answers
SOURCE: onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Posted on Feb 12, 2010
  • 308 Answers
SOURCE: My onkyo skw 200 sub woofer is blowing fuses as
The amp output stage or the power supply is shorted. Service shop type repair.
Posted on Mar 04, 2010
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
My onkyo skw 200 sub woofer is blowing fuses as soon as i plug it in
Mar 03, 2010 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
95 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
