Dish Network 6.0 Remote Control TV2 stops working when the PS3 is turned on on TV1
    Novelist:
    Champion:
  • 286 Answers
I would be happy to assist you! It sounds like the PS3 is causing interference. In this case, we would do what we call backfeed the remote so that the game console can no longer interfere with the remote. Please email me at becki.barned@dish.com so that I can assist you. Thank you!
Becki Barned
DISH Internet Response Team
Posted on Dec 07, 2012
4 Suggested Answers
  • 374 Answers
SOURCE: Dish Network remote wont control tv2 on my dual tuner
Your problem may be as simple as having the UHF antenna on the back of the receiver moved closer to the second TV. I suggest pigtailling it. This is a job best left to a professional due to the different configurations that may exist and assuring you have properly made connections. If this is an ongoing issue talk with the CSC agent and refuse to pay the service fee based on your past issues with the system. There are many other possibilities that could be the cause but this is the most likely and least involved approach and I am 99.9 percent sure this will solve your issue. Thanks for using Fix Ya.
Posted on May 18, 2009
  • 56 Answers
SOURCE: In single mode, my remote for TV1 works, but in
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
Posted on Nov 12, 2009
danbusa
  • 185 Answers
SOURCE: im trying to program tv2 on dish network itwill
Check the tab on the bottom of your remote, make sure it has the blue number 2 tab in it.
Daniel Busa
DISH Network Customer Service
Posted on Feb 08, 2011
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
When tv 1 is on, I do not have control on t.v. 2 with the remote to change channels fast forward or rewind.
Hi dhperezfamilmy name is Mike Houston of DISH Network and I was going over your post and withyour TV2 remote not working while TV1 is on there is a conflict between theremotes. What you will need to do is on TV1 remote press the MENU button 2 timesand it will take you to the System Info screen. On the TV2 remote press andrelease the SAT button and press the Record button one time and then press theselect button on the remote.
Feb 11, 2011 | DISH Network IR Remote Control
Cannot get it to work with dish network. It won't accept channel input either!
Hello! If your tv just won't cycle to the correct channel you can change the setting if its tv1 you need a channel scan if it's tv2 try these steps:
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Dec 31, 2010 | Insignia IS-LCDTV32 32 in. Television
My remote control only works for tv on & off and volume but not to change dish channel
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Oct 06, 2010 | DISH Network IR Remote Control
Can you buy a universal remote for TV 2 to change the channels? My remote for SAT DISH stopped working the lights on the top come on but I can not change the channel, view the guide etc...
The remote is an Ultra High Frequency remote and most universals are IR MAKING THEM INCOMPATIBLE.
Take the TV2 remote into the TV1 location and using the TV1 remote press MENU-MENU. You will now have a screen up that has remote addresses at the bottom. Take the TV2 REMOTE AND PRESS AND HOLD the SAT button on the upper left of the remote until all lights on top illuminate and release. Now key in a two digit number between 1-16 that is not either number on the screen currently and press the pound sign. The SAT button will flash three times now press the record button until the remote addy for tv2 changes to the new number.
You can cancel out of all of these screens with the TV1 remote. Now go to TV2 see if it works. If not try at the receiver. If it works there have Dish send you a new remote.
Feb 01, 2010 | DISH Network IR Remote Control
Remote does not work at all
Phil with DISH Network here. Ideally we would want to knowwhat model remote we are having issues with, but here are some steps thatshould help.
Step 1:
Check if the issue is with a specific button. If its just one button that isnot working we need to have the remote replaced.
Step 2:
Check that the correct remote is being used for the TV in this room. Use remotekey (Green "1" or Blue "2 UHF") to confirm itis being used in the correct room. TV1 is located in the same room as your DISHreceiver.
Step 3:
If UHF, check that your UHF remote antenna is securely connected to the "RemoteAntenna" port on the back of your receiver and that the antenna isupright.
Step 4:
If issue is with the TV2 remote, bring your TV2 remote with you to TV1. Access "SystemInfo" at TV1, using the remote that is NOT functioning, pressand release the "SAT" button then press and release the RECORDbutton on remote control.
Step 5:
If the batteries in the remote have not been replaced in the past 60 days,replace the batteries. If the remote doesn't light up after replacingbatteries, have the remote replaced.
Step 6:
Unplug the receiver for 10 seconds then repeat step 4.
Step 7:
If the remote is still not working the issue may be caused by IR interference.Find interference source (back lighting or power save mode on LCD TV's,fluorescent lighting in room, or direct sunlight). Getting rid of theinterference should fix it.
After completing all these steps if you're remote is not working give us a callfor additional troubleshooting at 1-800-333-DISH (3474).
Thanks for being a value DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Dec 25, 2009 | DISH Network IR Remote Control
Remote buttons light up, nothing happens , wont run the reciever
Phil with DISH Network here and happy to help! Here are some steps thatshould fix your remote:
Step 1:
Step 2:
We want to make sure that the correct remote is being used for the TV in this room. Use remotekey (Green "1" or Blue "2 UHF") to confirm itis being used in the correct room. TV1 is located in the same room as your DISHreceiver.
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
If you are using a UHF remote, find interference source (component(s)(VCR, DVD Player, etc.) near DISH receiver), adjust UHF antenna, or distance UHF antenna from receiver using coax cable.
Phillip Chang
Dec 14, 2009 | DISH Network IR Remote Control
In single mode, my remote for TV1 works, but in dual mode, only my remote for TV2 work. In single mode, both remotes can change channels, record, etc. In dual the Remote for TV2 turns on the blue light and...
Oct 28, 2009 | DISH Network IR Remote Control
Setting up remote 2
Ok lets assume you have the correct remote for the TV2 on a 322, you will need to take this remote to the TV1 location . Turn TV1 on and with the TV1 remote press menu-menu. You are now at the sytem info screen. Towards the bottom third of the screen you will see some wording that reads primary remote address and secondary remote address. Now with the TV2 remote press and hold the SAT button until all buttons across the top light up and release. The SAT button will be flashing. Now key in a two digit number between 1-17 that is unique to this remote only. Press the pound sign and the SAT button will flash three times. Now press the record button and the number you chose should now appear next to the TV2 icon. Are you good to go? If so exit out of all screens on TV1 and try thr TV2 remote at its location. You should be able to control the satellite now. If you can't ensure that the antenna on the back of the receiver is present and there are no obstructions in front of it. If you still are having issues - like you have to be at a certain point in the room- the remote antenna may need to be moved from the back of the receiver to the TV2 location Thanks for using Fix Ya.
Mar 18, 2009 | DISH Network 322 DTV Receiver
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
