Question about Kitchen Ranges
How do i replace the light switch on a Rangaire hood?
How does the rotary swtich come off? Can I get it off from the outside?
Why would 1999 Buick dash lights not work unless interior lights are on using the rotary switch for the headlights?
From your description I would have to say it is the switch. The switch you turn to put the interior light gas a variable resistance coil in it and it is probably broken.
I hope this helps,
Vinnie
Jul 10, 2015 | 1999 Buick Regal
Door ajar light stays on door won't close all the way
-Just disconnect the wire that hook up to the switch.
(Only on the effect door)
-Or remove the switch and if you can put a spacer to bring the swtich
to the outside little more. That will solve the problem.
mai
Mar 21, 2013 | Dodge Caravan Cars & Trucks
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Nov 30, 2010 | Leviton Decora Rotary Dimmer 600-Watt SP...
Replacement T handle on EasyGreen Rotary Spreader
I have looked for spare parts but you can buy a brand new spreader off of Ebay for £29.99.
Regards
Alan Hood
ami-man
UK
Sep 26, 2009 | Garden
Underhood lamp
i am assuming you have checked the wire that connects to the light for 12 volts when the hood is open. these lamps work on a switch that is position sensitive (hood open= light on hood closed =light off) this internal switch could be faulty,therefore you need to replace the light fixture itself(remove the two bolts holding it do the hood and unplug the wire) Or what i have found with most of these, because they are subjected to the outside elements the connections for the light bulb get corroded and the 12 volt current isn't reaching the bulb. try removing the bulb and clean the contacts with a small wire brush and some contact cleaner. Also check the bulb,sometimes they look ok but the filament is burned and can some times make contact and cause the light to work intermittently
hope this helps.........thanks for choosing FIX YA!
Aug 08, 2008 | 1996 Oldsmobile Cutlass Ciera
Interior lights
its your door penn switch which is in control of turning on the light, when u turn right, so start with the passenger door pin switch, then check all switches as well, replace one or all the malfunctioning swtich,wiggle or slightly touch the switch to see if the light is affected if it is replace the switch
Aug 01, 2008 | 1997 Honda Accord
Kitchen Ranges Logo
386 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
