Question about Dell Inspiron 1300 Notebook
Dell Inspiron 1300. on starting the laptop only a DOS Screen appears. It says, "Windows could not start because the following file is missing or corrupt: \windows\system32\config\system. You can attem
  • Dell Master
  • 7,627 Answers
Insert the Repair CD, unplug from AC, remove battery, plug into AC, Take a look at this before you start: http://answers.yahoo.com/question/index?qid=20071009083747AAdQgO7 AND THIS: http://en.community.dell.com/support-forums/disk-drives/f/3534/p/18165223/18288209.aspx#18288209
Posted on Dec 07, 2012
4 Suggested Answers
harvester3
  • 181 Answers
SOURCE: windows. file missing or corrupt system32 config
If you're running XP, boot to the XP cd, if available (if not, mail me and I can send you a dell XP disc)
Pass the first repair opportunity, press f8, then it should allow you to do a windows repair. Do that. You will keep all your files, but windows will be completely reloaded. Will need to get updates, but that's it.
Good luck
Posted on Nov 22, 2007
  • 8909 Answers
SOURCE: it states windows could not start because file
Check that the Bios will allow boot from cd by going into the bios and nselecting DVD drive as master or first boot device.
Re start the notebook with the disk in the drive and then it will boot from the CD. Then try again to repair your system.
Hope that helps.
Posted on Nov 20, 2010
  • 3940 Answers
SOURCE: Dell Latitude 810 will not
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Posted on Jul 17, 2011
Dell inspiron 1300 left mouse key not responding
If you go to start in the bottom right corner of your screen click on it then go to control panel open control panel windows defender will be in there you can turn it on there but if you have other anti virus software running they will manage your anvirus and internet security over windows defender.
Jan 01, 2013 | Dell Inspiron 1300 Notebook
Latitude d620
You have either missing or corrupt boot or system files. Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 23, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
I can use my Dell OptiPlex GX280 PC Desktop says that windows could not start because the following files is missing or corrupt: \windows\system32\config\system
You'll need a operating system disk or repair disk to run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | Dell OptiPlex GX280 PC Desktop
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
My dell inspiron 1300 always show white screen display
NEED TO FIX A BAD SECTOR ON A HARD DRIVE 1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME
Jan 21, 2011 | Dell Inspiron 1300 Notebook
When I start up my Dell inspiron 1300 a message comes up which says "windows could not start because the following file is missing or corrupt: \windows\system32\config\system Please help wat do I...
if you have the laptop recovery disc, then using the disc reinstall the windows. If you do not have then use a boot-able CD and reinstall/repair windows. it seems some system file missing.
Aug 31, 2010 | Dell Inspiron 1300 Notebook
My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 09, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 1300
Follow this process ---> Press and Hold CTRL + F11 by the time you see the blue line that has www.dell.com after the dell splash logo and then it would show up the symantec ghost --> choose restore then follow the rest of the affirmative prompts
Aug 09, 2008 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 Notebook Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
