Question about Refrigerators
Maytag ice 2o mfi2568aes ice maker will not stop making ice unless turned off
Ice maker will not stop making ice unless turned off. dispenser works fine. when moving lever switch clicks.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the part number on the ice maker?
Posted on Dec 07, 2012
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Posted on Aug 30, 2008
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Posted on Sep 08, 2008
SOURCE: Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Posted on Jun 05, 2009
woodchuck789
  • 4066 Answers
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Aug 29, 2009
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker is not making ice
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Aug 11, 2011 | Maytag MFI2568AE Side by Side French Door...
Maytag mfi2568aes makes continuous buzzing noise when water dispenser is depressed (sounds like is coming from rear of machine). Water comes out, but at a trickle. Ice is fine
From your description, the only thing I could think that MIGHT cause those types of indications is the dual water value. http://www.partselect.com/PS2069865-Whirlpool-67006322-Dual-Water-Valve.htm?SourceCode=1&ModelNum=MFI2568AES
IF you are sure that the ice maker fills NORMALLY. If it doesn't then I would suspect the filter.
Jun 12, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Not making ice. dispenses water though
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Won't make ice....still dispenses water, but won't make ice.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator not working properly
dispenser board needs to be replaced. There was a recall on certain Ice 2O units. Call Maytag and see if your unit qualifies.You will need model and serial number.
Jul 23, 2008 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
