Question about Vacuums
MANUAL FOR A POWERMAX VAX CARPET CLEANER
HI I JUST NEED THE MANUAL FOR THIS PRODUCT
  • Vacuums Master
  • 18,392 Answers
You can download the manual off the link below free.
http://www.vax.com.au/Downloadsusermanual.html
Posted on Dec 07, 2012
ukvacfan
  • 328 Answers
SOURCE: VAX HOOVER PROBLEM?
The 121 should only have the main filter ring taken out before the reservoir tank is put in which easily just falls into the main dust tank area. Make sure though that the bin's square edge is at the front where it rests at the front of the Vax where the hose comes out. Then unhook the pump to lay it in the water tank and the motor should be able to jam ontop clipping both sides down to lock. Perhaps you are putting the reservoir bucket in the wrong way.
Posted on Mar 07, 2009
ukvacfan
  • 328 Answers
SOURCE: VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Dont forget to rate appropriately, thanks.
Posted on Mar 27, 2009
EwingElect
  • 276 Answers
SOURCE: VAX 2000 manual lost
If you want a manual for the Vax 2000 hopefully the one on the Australian website will help.
Try http://www.vax.com.au/Downloadsusermanual.html and you'll see V2000 listed.
Posted on Mar 31, 2009
skyblue67
  • 71 Answers
SOURCE: Do not have manual for Vax rapide carpet washer
Hi you caan usually get a user manual that you can download from this site
Posted on Jul 19, 2009
  • 4044 Answers
SOURCE: there is no water coming
There is a leak or blockage due to Calcium or something building up in one of the nozzles. If there is a small leak on the hose or one of the fittings there will not be enough suction to get the fluid through the hose. If the nozzle has a problem with build up you will need to remove them and soak them in a solution or manually clear them. I recommend using CLR to soak them in and clear the nozzles. I would also take the machine outside and put CLR in the water solution tank and let it sit for about an hour, run the machine for 5 minutes or so the circulate the solution through the pump unit and let it sit for another hour then use the machine running outside until it cycles all the fluid out of the tank, rinse the tank and it should work properly after that. If it doesn't there is a mechanical issue in the pump and you will need to take it to a shop to get it repaired. All of this assumes you or someone has used regular tap water in the machine for normal use or it has been used and left with solution of water in the lines when stored.
Posted on Feb 03, 2011
How can I download user manual for Vax 2000 wet and dry carpet cleaner ?
Try Googling (vax)(2000)(manual) without parens.
Jun 17, 2017 | Vax Vacuums
Hi I bought vax vrs19w carpet cleaner and it came
I found this link for you, hope it helps!
http://library.vax.co.uk/resource/964/vrs19w/user-guide.pdf
Sep 19, 2014 | Vacuums
I have lost manual could you please showfor vax rapide spruce carpet cleaner
Ok, go to www.vax.co.uk and when you bring up their web site, click on the large Support box at the top, this will lead you right to how to download a manual. I just did it, it was easy. You can type in the model no. or click on the carpet cleaner photo and it will easily lead you to the manual. take care and good luck, Andy
Mar 09, 2011 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
I have a new steam vac power max without instructions I need to know how to operate it
Hiyas ive found you an online downloadable manual go to this site and after its loaded look where it says product manual and click on that then click on the product manual again and it should open a new window showing the manual, when this window is fully loaded click on the disk top left to save a copy to your computer for printing
http://home-solutions.hsn.com/hoover-12-amp-steamvac-powermax-carpet-cleaner_p-2750224_xp.aspx
Jul 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Specificially:
Mar 27, 2009 | VAX Appliances Vax X5 Bagless Upright...
Vacuums Logo
78 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
