Question about Toshiba Satellite L645D-S4033 2.30GHz AMD Turion II P520 4GB 250GB DVD/-RW WebCam 14" Win 7 HP PSK0QU-00Y004
Uninstalling workstation The Toshishab Workstation boots up at start up and slows my internet connection severely. I don't use it and want it removed.
  • Toshiba Master
  • 10,322 Answers
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Mar 19, 2013
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
Cannot install new hard drive on HP xw4400 Workstation
Check the to see if its in master or slave configuration.Also a great boot tool is Hiren's BootCD and here the link below.If you a tech to call you for a step by step help go to our website and the that link is below as well and take care.
http://www.hirensbootcd.org/download/
http://www.ezsystemrepairs.com/
Nov 08, 2012 | HP xw4400 Workstation PC Desktop
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
We have a Dell Precision T5500 Workstation. We have installed 72GB (9 x 8GB) with a riser. Windows & the BIOS recognise all 9 modules for 72GB total, but only 56GB is deemed usable. When we boot, we...
Go to www.support.dell.com andselect "I'm looking for drivers and downloads". If you don't have theproper version of Adobe you will be prompted to install it. Once installed returnto "drivers and downloads" and enter the "service tag",(serial number) of the computer. Dell keeps a listing of drivers for everycustomer's computer they sell. Memory failure on DIMM 1 - try swapping memory sticks and see if error moves to another DIMM slot. If it does then you have a bad slot on motherboard or riser or riser connector on motherboard.
Aug 02, 2011 | Dell Precision T5500 Computer Workstation ...
How do you get into safe mode on hp workstation xw8000?
Try pressing F8 as you boot
Also try Del as you boot if F8 doesn't do it
Jun 22, 2011 | HP Workstation Xw8000 PC Desktop
I have had problems when starting from cold - the workstation dell Precission 670 starts to boot then it gets to the window screen for only a few seconds and the screen goes dark and the "B" & "C"...
B and C usually indicate a drive failure. if issue only occurs on COLD boot and successive boot attempts gain access to the OS, then the most likely issue is that the HDD is slow to come to operating speed, (Drive has to be at Approx 97% of rated rotation speed before is can successfully read) on drives where the spindle is slow to come to speed, a cold boot then successive warm reboot will often gain access to the HDD/OS
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
One problematic issue on diagnosing this is that you only have 1 opportunity to run diags (The cold boot) and get a reading on if the drive is failing to read (also because diags are generally slower to load, the drive may come up to speed before the diag actually runs)
If issue is problematic and getting worse, I'd replace the HDD
Oct 22, 2010 | Dell Precision Workstation 670 PC Desktop
I want DELL workstation (not a PC) Configuration & Quotation. Thanks
I want the workstation (computer) of DELL,
can you help me ? I want the quotation & configuration of DELL Workstation. not a PC ? Please send me.
Thank's
Dev R. Patni
Jan 24, 2010 | Dell Precision Workstation 670 PC Desktop
D-Link DES1008D 8 port fast ethernet desktop switch
By using it, of course you have this items to connect it with internet:
  1. UTP Wire with Connectors at end each PC or Client Workstation.
  2. Make sure every PC or Client Workstation have its own LAN Card.
  3. To connect on the internet is to know what is IP Address, Gateway Address & DNS Server Address settings on your LAN connection.
  4. Lastly, It should have internet provider in your place.
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Some of my workstation immediately disconnects fron internet
That sounds (apart from a really heavy load on the little router) very much like you are running out of DHCP addresses.
Are your computers set to static or DHCP?
Are they connected via cable or wireless?
What is your DHCP range?
What is your lease time?
If the computers get rebooted i.e. 6 times per day and your default lease time is 1 day, that means that only one computer is blocking already 6 IP addresses per day. 33 computers therefore are blocking 198 addresses, which is almost your entire spectrum from 192.168.1.2 - 192.168.1.254.
So either set them to static IP or shorten the lease time.
Jul 04, 2009 | Computers & Internet
Hp laser jet 4 plus printer
Need some additional info: -Network based or connected direct to the workstation? -How big are the pdf files? -Has anything changed with the printer, workstation/server host?
Dec 03, 2006 | HP LaserJet 4 plus Printer
Toshiba Satellite L645D-S4033 2.30GHz AMD Turion II P520 4GB 250GB DVD/-RW WebCam 14" Win 7 HP PSK0QU-00Y004 Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
