Question about Canon Electronic Typewriter Lift Off Tape Models - AP100/150/ES3/5/10/11/13/15/20/25/33/S58/68/QS200/300/210/310AP105/110/155/160/200/300/340/350/360/400/500/560/5015/5415/9017/9417 - Box of 6
The characters that type do not match the keys pressed on a Canon QS-200 typewriter. How do I fix this?
Stops typing mid line
Type to the stopping point, press the margin release key space to the desired location, press R. margin key.
Jan 08, 2014 | Olympia Mastertype 3 Typewriter
My Smith corona typewriter types the wrong characters.
Check to see if you are in KBII or a language mode if not look for bent or broken spokes on the printwheel.
DickyO
Apr 06, 2012 | Smith Corona Wordsmith 200 Typewriter
My Canon QS 310 typewriter has been programmed to type letters instead of numbers. How do I get the numbers back?
Turn off machine. Let it sit for one minute. Hold down ALT and CTRL key with left thumb and forefinger while striking letter a with right forefinger. Hopefully, this will "de-confuse" memory.
Apr 04, 2012 | Office Equipment & Supplies
How do i correct one digit at a time. I only seem to be able to correct one word at a time.
Hold down code and press the correction button to switch from word correct to character correct and back. Note to correct one character only you can simply use the backspace key.
May 14, 2010 | Smith Corona Wordsmith 200 Typewriter
THE CHARACTERS TYPED DOES NOT MATCH WHEN APPEARS ON THE PAPER ?
What model typewriter do you have? Most have a setting key on the keyboard, usually on the left side to change keyboard or printwheel settings.
Jun 22, 2009 | Office Equipment & Supplies
The shift key is typing the right character on the numbers row
Look for key or slide switch that says KBii press the code and that key or move the switck.
DickyO
Jun 18, 2009 | Brother ML-100 Typewriter
Smith Corona SD 250
I have a Smith Corona wordsmith 250. The Daisy wheel is not aligned with the striker, it is two characters off. How do I fix this alignment??
Mar 26, 2009 | Smith Corona Wordsmith 200 Typewriter
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
Brother ML-500 Typewriter Typing the wrong characters
The printwheel is not in correctly. the printwheel has a bent spoke or the printwheel homing sensor needs cleaning. Lawrence
Feb 14, 2008 | Brother ML-500 Typewriter
Critical technical help needed
Open the top cover and you will see a switch on th right side that allows you to select alternate keyboards. Make sure it is set to the #1 position
Aug 09, 2007 | Brother GX-6750 Typewriter
Canon Electronic Typewriter Lift Off Tape Models - AP100/150/ES3/5/10/11/13/15/20/25/33/S58/68/QS200/300/210/310AP105/110/155/160/200/300/340/350/360/400/500/560/5015/5415/9017/9417 - Box of 6 Logo
old marine
old marine
