Question about Ricoh Aficio 3025P Black and White Copier
What causes the copy to be lopsided when using the feeder
  • Ricoh Expert
  • 1,326 Answers
I'm not sure what lopsided means??? Are you saying that the image is crooked? If you feed the paper 180 degree then the way you are feeding it now, are they still crooked? Also, do the pages get jammed? Also, look to see if one of the hings are broken? If one is broken, it's a dead give away for your problem. If that is not the problem, I would loosing up the screw that hold the adf on and move the adf a bit till the copies come out straight. Once the copies are coming out straight, tighting the adf hing screws and you are done...... Good Luck
Posted on Dec 09, 2012
Our copystar is creating a dark line on the right side of the paper
There are a number of things that can cause this problem, below are a few things you can try.
1. Remove the process unit out as if you were going to remove a jam. There is a green piece of plastic used to clean the main charge unit. Slide it to the left then back to the right. Make sure it is seated all the way to the right in it's home position or it can cause black lines.
2. If you have a document feeder on the copier is the line only when using the document feeder?
- Determine if it is by making a copy from the glass.
- If it is only when making a copy from the document feeder then clean the small **** glass just to the left of the large glass. This glass is used only when making a copy from the document feeder.
3. If you wipe your hand across the copy and the toner wipes off then fixing unit should be replaced.
I hope this is helpful,
Shawn
Feb 18, 2011 | Copystar CS-1500 Copier
It works great in all aspects, but when I make a copy of something there is a black line about 2.5" from right side of paper (only when I use the auto feeder to copy) If I lift the lid and palce the paper...
You need to lift the document feeder and clean the small **** exposure glass located to the left of the main exposure glass.Any foreign substance on this glass(ink, glue, correction fluid,etc.)will cause lines on copies when you use the feeder.
Oct 08, 2009 | Samsung SCX-4725FN All-In-One Laser...
Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Mar 16, 2009 | Brother MFC-9440CN Laser Printer
ADF has something on it causing a stripe on all copies
Lift the document feeder and clean the narrow glass, (next to the glass where you place your originals). Documents are scanned across this glass when automatic feeder is used, thus a small piece of dirt becomes a line down the page.
Feb 24, 2009 | Canon ImageClass D880 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark x2356 all in one printer
I had same problem. Check inside at lower alighnment rollers for any obstructions. Mine was a Sharpie marker wedged at rollers.
Jul 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
Upper feeder tray copies work fine, main feeder does not print, makes odd noise
Found the answer.
Problem:
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position. Solution: Free the Spring, by rotating it. Ensure that the Pawl moves freely in and out, and engages with the clutch.
Apr 02, 2008 | Sharp AL 1631 Copier
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
Ricoh Aficio 3025P Black and White Copier Logo
156 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
