Question about GE GTH17DBDCC 16.5 cu. ft. Top-Freezer Refrigerator with 2 Adjustable Wire Shelves, Gallon Stora2 Clear Crisper Drawers, Wire Freezer Shelf and Optional Icemaker: Bisque
The refigeratore is not cooling
Every thing is working , but is not cooling,
    Top Expert:
  • GE Master
  • 9,472 Answers
Is the compressor running?
Posted on Dec 07, 2012
How to thaw a 20 lb turkery in refigeratores
Would need to know a bit more information.
1 Type of refrigerator (top freezer or side by side or bottom freezer)
2 How soon do you need turkey thawed
On 1
Top freezer type = place turkey on lowest shelve in a pan to catch water.
On Side by Side type = this will take the longest to thaw as it has a consistent temp through out.
On bottom freezer type - place turkey on highest shelf of refrigerator.
Nov 21, 2013 | Refrigerators
Not cooling very good anymore. its cool but not that good! all the settings work. one thing i did notice is that ice builds up on the cooling coil from compressor! ( ge room ac model # ast05lcs1...5500...
Your intuition is right, the ice buildup is why it's not cooling so well now: the evaporator isn't getting the correct air flow and surface area for heat exchange. The 1st thing you might want to check is to make sure that it's draining properly. The 2nd thing you might want to do is to check that the room is over 100 sqft. If you'r only cooling a tiny bedroom, the AC's basically oversized: your cooling already cooled air, so it freezes. The actual reason that is freezes is because the condition is just right for the immediate area near the evaporator to be at the saturation point. Think of it in terms of weather: warm and humid air collides with cool air and it begins to rain. The temperature drops further, and the rain turns into snow. One thing you could try to make it not freeze-up is to adjust the temperature setting a few degrees or change the fan speed.
Aug 04, 2011 | GE ASQ05LK 5,050 BTU Room Air Conditioner...
Pls help me solve the issue of overheating in my passat v6 wagon 2001 model
overheating is a sign that there is a cooling circulation problem. the first things to check are: make sure your water pump belt is at the proper tension and is infact there ( not broken ),, next thing to check is the coolant level and antifreeze to water ratio:, also make sure your cooling fans are working, next thing to check is the operation of the thermostat --if it is bad then it needs to be replaced.. you might also want to do a cooling system flush - just to make sure everything stays nice and clean for the future.
c...
Feb 17, 2011 | 2002 Volkswagen Passat
My fridge isn't cooling at all. Lights are working but isn't cooling. GSS201EMB WW
need more information please. make model other things i m working in the dark. could be several things.. ok
Feb 12, 2011 | Refrigerators
The top part wont keep any thing cool but the freezer part works grand
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 20, 2010 | Refrigerators
Refrigerator will not cool freezer is working fine do i have a warrenty
For warranty call where ever you got the thing...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 30, 2010 | Refrigerators
Frigirator is not cooling
You may want to try the simple things first. There are proably cooling coils underneath the Ref. Which if not clean often can lead to no cooling problems. Remove front lower panel (proably just pulls off) you will then see cooling coils which will have lots of dust etc collected in it. Best thing to clean with is a vacumn cleaner using a crevice tool. Be careful don't use shrp object.
Aug 07, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
RCA MM61110 Problems
I took the back panel off and noticed that one of the cooling fans was not working..... apparently the computer tells the tv that it will not be able to cool. I cleaned things using air and basically followed the wires for the cooling fan and wiggled them... lol.. works fine now
Jun 09, 2008 | RCA MM61110 61" Rear Projection Television
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
GE GTH17DBDCC 16.5 cu. ft. Top-Freezer Refrigerator with 2 Adjustable Wire Shelves, Gallon Stora2 Clear Crisper Drawers, Wire Freezer Shelf and Optional Icemaker: Bisque Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
