Question about Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker
We took the pot away from the heat and let it cool. After checking that it was assembled properly, put it back on a much lower heat setting and it is fine now. It appears that the heat on this pot has
This was our conclusion and response to our new pressure cooker making a sound like a loud fog horn after 3 minutes of exposure to high heat....
  • 190 Answers
Here is a detailed description of how the pressure cooker should work. The "fog horn" should not activate until the second red ring is out of the housing.
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Posted on Jan 20, 2014
  • Laura D.A. Pazzaglia
    Laura D.A. Pazzaglia Jan 20, 2014
    Yes, the cooker needs very, very low heat to operate. High heat only when it is brought to pressure, then the flame should barely be visible the heat setting on an electric range should not go over 2.
    http://www.hippressurecooking.com/pressu...
Why is lower radiator hose cold when motor is at operating temperature?
Ensure thermostat is installed right side up or it wont allow proper flow. If thermostat is correct other problems could be Air in cooling system, low coolant level, plugged rad internal, water pump failure,coolant flow valve stuck,internal engine combustion leak to cooling system.
Auto Repair Diagnostics How to Diagnose Cooling System Problem
Jan 16, 2016 | 2007 Ford Focus 2.0
Tip
Haier Thermoelectric Wine Cooler
This wine cooler hasn't held temperature for months, even though during the winter my living room gets to 58 F at night. I've had it maybe a year.
I took the back off, and 2 of the 3 heat sinks felt cool, which means the thermoelectric pack was just conducting cold out of the cabinet in 2 of 3 cases. The third one felt slightly warm, as it should. I checked that the cool ones had 12 v to them, they did, so they should have been pumping heat out.
I put bowls of ice inside the unit, and when the temperatures got down to the set points, I heard relays click, so I figured the control unit was OK.
I removed one of the TEC modules that was cold on the outside, and taped up the hole with masking tape.
I unplugged the fan from the circuit board and unscrewed that fan assembly from the heat sink.
I then clipped the leads to the TEC unit, cut away the blobs of hot melt glue, and disassembled the cooling module. I took the TEC device and hooked it back up, making sure it had voltage to it. After awhile, both sides just felt slightly warm so I knew it was bad.
Got on line and ordered 4 (to have spares) TEC1-12703 coolers. I have thermal grease. When the parts come, I will re-assemble and should be good to go.
I don't know what blows the TEC devices, they should be very robust. Maybe Haier got a bad bunch of them, I read almost all bad reviews on these wine coolers.
on Apr 03, 2010 | Haier HVTB40DPABS Wine Cooler
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Can't get the top off of a stainless steel pot. The top got on the bottom and I can't get them apart.
Try heating the pot on the stove - just a slight bit because its empty. The pot and lid probably sealed themselves together becausethey were put away while they were warm, and as they cooled, the air in them shrank, creating a vacuum.
Dec 19, 2012 | Crock Pots & Slow Cookers
Asus p4gemx motherboard heatsink bracket jumbingout,systemrestart frequently
The cooling fan and assembly is for maintaing the CPU heat.
When the heatsink is not seated on the CPU proper then the heat will rise and cpu stop function
You check the bracket lock is broken or not
Make sure the lock is put proper
or replace the assembly.
Apr 15, 2011 | ASUS P4GE-MX Motherboard
It will not turn on
Hi Woodman22191,
I suggest that you do a couple of visual inspections first before doing anything drastic. Here's a list of things that you should check :
- Is the magnetic cord assembly properly attached to fryer socket ? - Is the electrical cord assembly plugged into electrical outlet? - Is the Power ON/OFF Switch is set to ON? - Is the Heating Element Assembly correctly assembled? Make sure Heating Element Assembly is properly installed on base. - Are you using too much or too little oil in the pot? Make sure that you use the recommended amount of oil in the oil pot.
If these things above does not fix the problem, you may need to Reset the Fryer. - Press Reset on Heating Element/Control Panel by inserting a paper clip or any small pointed object into the opening labeled RESET.
I hope this solves the problem. All the best to you. Good luck.
Dec 06, 2010 | Hamilton Beach 35030 Deep Fryer
Help .Do i put water in my slow cooker!!
do not put water in to the metal pot. place the ceramic pot inside the housing or metal part add your meal and set to high or low depending on how long you will be away and enjoy your food.
Jan 26, 2010 | Crock Pots & Slow Cookers
3 beeps when in failure. makes ice for several hrs some times. compresser heat extreme. this unit is water cooled but h2o out put seams to low what should out put flow be?
First, 3 beeps means that the unit was in the freeze cycle too long and the 60 minutes back up timer kicked in and took over.
Now, for the water flow/ head pressure water cooled control.
You set the water flow for what ever it takes to achieve a head (High Side) pressure of 270 psi. the gallons per minute are of no matter. It's the pressure that you want to achieve and maintain.
If you fix the head pressure problem, the beeps should go away.
If you don't have a gage set, then measure the temp of the exiting water from the condenser. It should be in the 104 to 115 degree range. Any lower or higher, and the unit will not run like it was designed to do.
Hope this knocks it out for you.
Oct 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Jan 22, 2009 | Maytag 24 in. MDBS661A Built-in Dishwasher
Keeping Consitant Heat
After looking at this you need to purchase either cermic briquettes or plates. Make sure you buy enough to cover the lower grate completly.
Thanks
Zerko
Aug 26, 2008 | Char-Broil Santa Fe - 491 Grill
Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker Logo
118 people viewed this question
Top WMF Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a WMF Kitchen Appliances - Other Expert? Answer questions, earn points and help others
