Question about GE GTH17DBDCC 16.5 cu. ft. Top-Freezer Refrigerator with 2 Adjustable Wire Shelves, Gallon Stora2 Clear Crisper Drawers, Wire Freezer Shelf and Optional Icemaker: Bisque
Not cooling every thing is running but no cooling
    Top Expert:
  • GE Master
  • 9,472 Answers
Does the compressor run?
Posted on Dec 07, 2012
Why isn't my fridge cooling down?
There are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. ... Note: The compressor should usually be running whenever any of the fans (evaporator fan in the freezer and condenser fan by the compressor) are running.
Jun 27, 2017 | Refrigerators
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Trane XE 1100 outside fan works but no cool air in house
Without much to go on, it sounds like you have a leak and lost some charge. It could be many other things but this is a start. I would check to see if the compressor is running, and the indoor fan is running. Is the filter clean? Check these things first, and then call a contractor if they check out ok.
Aug 08, 2012 | Heating & Cooling
Cooling fan not running as temp. heats up.
most time coolant temperature sensor faulty.but check cooling fan fuse and relay.then hot wire the cooling fan if fan runs.problem in the fan wiring or pcm.if every thing else okay.if cooling fan dont run when hot wired the cooling fan need replacing fan motor has internal open winding circuit.
Apr 15, 2011 | 1995 Buick Skylark
Compressor is running but ac not cooling
The unit leaked the refrigerant and so it does not cool even though it is running... Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Royal Sovereign ARP9011TL Air Conditioner
Refrigerator not cooling - freezer is very cold
Hello there:
There are several different things that could make your refrigerator not cool properly.
I have compiled a list of things that you should check out and how to check them ok
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the refrigerator completely dead? If so, Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
I will continue the rest of the post in a seperate post to allow for full detailed instructins
Apr 15, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Refrigerator not keeping things cool and freezer
this is usually caused by dirt either around the fan if its a built in fridge, or around the cooling fins at the back of the fridge.Make shure you unplug the fridge before investigating what is wrong.
Apr 13, 2010 | Hotpoint HSS25GFP Side by Side...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
GE GTH17DBDCC 16.5 cu. ft. Top-Freezer Refrigerator with 2 Adjustable Wire Shelves, Gallon Stora2 Clear Crisper Drawers, Wire Freezer Shelf and Optional Icemaker: Bisque Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
