Question about Nortel Meridian M7208 Corded Phone
When I unplugged my phone and plugged it back in, when I push my speed dial button it picks up a phone line now. How do I reprogram that button to be speed dial?
    Scholar:
  • 277 Answers
Feature * 3
Press that button
Feature then 0
If still an issue then do F * 0 and press that button, need to know what is says on the display as you cannot override Lines,Intercoms, Handsfree, Huntgroup keys.
Posted on Dec 07, 2012
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
    Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
    Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
    Carl
    Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
    How do i reprogram my speeddial numbers on jazz 4400?
    Hello.
    From NorStar Support:
    To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
    1. Press the Feature button, then * 4
    2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
    3. Enter the telephone number, then press the OK softkey
    4. Display will show: "Entry xx stored"
    If the above doesn't work, try:
    1. Press [Feature] [*] [4]
    2. Enter a two-digit code from 71 to 94.
    3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
    4. Dial the telephone number you want to program (up to 24 digits).
    5. Press [Hold].
    6. Record the code and number you have just programmed.
    Hope this helps.
    Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
    How do I program a speed dial out side number on the buttons to the right?
    What happens when you dial "9" on the intercom? If that gets you an outside line, then press PROGRAM, one of the buttons, and dial 9 plus your number and STORE.
    Hmmm...Speed dial :-)
    If you get a vacant line at "9", then you need to reprogram your 400 line access on your phone sytem to disable the vacant lines.
    Carl
    Aug 31, 2010 | Panasonic KX-T7731 Corded Phone
    I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
    Why are you pressing the feature button?
    Press feature then answer. You envoked ringing line pick up.
    Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
    Press feature, then 3 and you've changed your ringtone on a series i phone.
    Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
    Problem with speed dial buttons
    to program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
    Feb 23, 2009 | NorStar M7324 Telephone
    Program speed dial buttons
    To program a speed dial for an outside line: Pick up the handset, press #00, press the button to be programmed, press *21, then enter the number to be dialed (including any dial out number and areacode).
    To program a speaad dial for in internal extension: Pick up the handset, press #00, press the button to be programmed, press *22, then enter the ext to be dialed.
    (Once you hit #00, you can also follow the screen prompts).
    Jan 21, 2009 | Avaya 4412D Corded Phone
    Storing Speed Dial Phone Nmbers
    Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
    Feb 26, 2007 | GE Telephone pr521w
    Nortel Meridian M7208 Corded Phone Logo
    87 people viewed this question
    Top Nortel Lands Phones Experts
    george  peters
    george peters
    dan4261
    Level 1 Expert
    Shehu Pro
    Shehu Pro
    Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
