Question about Proform XT 70 Treadmill
How do you adjust belt
Belt is rubbing and needs to be recentered. How do we realign it?
    Top Expert:
  • Proform Master
  • 12,223 Answers
Please see the Video and proceed according. God bless you
Posted on Dec 07, 2012
How do I adjust the belt. It has moved over and is rubbing against the rail on one side. I have the tool to make the adjustment but can't find the manual! !!
the adjustment is to realign the roller that the belt runs on as it is now not parallel to the other roller
so the allen key or spanner will fit in one end of the roller shaft and move it forward or back
go google and type in-- operators manual for ( make and model of machine) and find the pdf version download.
Oct 08, 2015 | Exercise & Fitness
Noisey belt when walking
the belt may need adjusted also if the belt is off canter it will rub causing an annoying sound due to it rubbing some parts inside the base. try adjusting the belt if you feel you can if not there are places that will do it for you. I hope all is well.
Jun 28, 2014 | Sole Fitness Exercise & Fitness
Misaligned drum/pulley
realign the pulley to where the belt runs in the middle
Feb 22, 2018 | Washing Machines
The belt has shifted to the left, how do I move it back over? And it sounds louder than normal.
Check the rear endcaps for damage. If they are OK, find the allen key that came with the treadmill (you used it to assemble the machine) and go to the back of the machine. If the belt is rubbing, find the left adjustment bolt and turn the screw 1/2 turn clockwise. Now, by hand move the belt a couple revolutions. If it still rubs, repeat the procedure till the belt stops rubbing. Now run the treadmill about 3MPH and fine adjust the belt by turning the screw 1/4 turn until straight.
If the belt is not rubbing, run the machine (3MPH) and adjust the left bolt clockwise 1/8 - 1/4 turn watching closely till the belt is centered.
Feb 27, 2011 | Epic View 550 Treadmill
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
The belt keeps going to one side+ rubbing,, is there anyone that
there should be adjustment screws on the rear roller.
only adjust one of them (usually the left) if the belt rubs on the left turn the screw clockwise 1/4 turn and if the belt rubs on the right turn counterclockwise. Make small adjustments until the belt stays in the center
Mar 24, 2010 | Proform 6.5q Treadmill Walking Belt
Noisey and recently smells like rubber. maybe a/c
You may have a frozen bearing on the tensioner or belt idler. This will cause the belt to burn and smell. I think you are on the right track. I would remove the belt and spin the idler and adjuster by hand to see that they are free and don't have excessive play in them. Replace as necessary.
Nov 05, 2009 | 1999 Chevrolet Silverado 1500
Proform XT 70 Treadmill Logo
76 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
