Question about Epson Stylus Pro 4800 InkJet Printer
No prints It seems to be working otherwise. Just nothing prints. Or maybe a 1" wide strip down the left(when facing paper feed) side of the paper, usually blue. And faint. And I have run the cleaning and checks multiple times. It seems that the blue ink is out. When I removed it I noticed there was ink on the outside of the cart and on the lil circuit board thing on the cart. I took all the other ones out and the one next to the blue had some ink on its case and wee circuit board also. The other two seemed fine. There sounds to be ink in the black and yellow carts. Any ideas? I got this for free from a formere boss as he said it just stopped printing.
  • 33 Answers
First thing to do is load the software. Make sure that all of the cartridges have ink, and are being recognized by the printer, and you get a satisfactory nozzle check. You will want to make sure that the chips on the cartridges (and the pin connectors) are clean and without ink/residue.
Posted on Jan 12, 2009
Xerox 3250 printer
The transparency should have a white peel off strip! Without that the machine doesn't know it feed paper. Some transparency paper will have a backing sheet you peel off after printing. Check Staples for correct type.
This should be the edge that feeds first and should be on the on the non print side. if your not sure which side is printed on (face up / face down) open tray and draw an X on the top sheet.
then print anything and see if it prints over the X. If not then put peel off strip on the side (face up / face down) not printed on .
Oct 02, 2016 | Xerox Phaser 3250D Laser - Monochrome...
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
When we try to print keeps saying load paper even although there is paper in feed tray. We have tried removing and replacing apper still same problem Printer just does not seem to register that there is...
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Good Luck!!!!!
Sep 24, 2011 | Lexmark X4530 InkJet Printer
My printer will not pick up paper. I have tried cleaning the rollers and blowing dust out with an air can. Is there anything else I can do? The problem started suddenly. I printed a document and then...
if you have cleaned your feed rollers with rubbing alcohol and a clean cloth... and dried the rollers off... then your next step is to replace them... nothing else...
Dec 23, 2009 | HP Photosmart 3310 Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Paper missfeeding
seems since one side is working that you might have a bad motor in your printer. i would take it back to the store you bought it from, assuming your warranty is still within its validility .
Jul 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
Epson CX5000 Paper will not load. Tries to but says paper jam even when there is no paper jammed. Blank pages will go through during reset but not otherwise.
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results? Once we have this information we will try to fix the unit through email support.
Apr 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Jul 03, 2007 | HP DeskJet 5650 InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
