Question about Makita 9553NB 4" Angle Grinder
Grinder only works when screws are loose on the head
My grinder stoped working. Tried to get inside to clean it up. Found that when I loosen the top screws and seperate the head from the body a little it works fine, but when I tighten the screws back it stops working. I cant seem to get inside to see what the problem is.
  • info794 Jan 13, 2009
    How do I know if it's the bearing and where can I get parts? Thanks
  • info794 Jan 15, 2009
    Thanks for your help. I think it's actually the carbon brush set. I've ordered new ones. I'll write back if that does'nt work.
  • 2,176 Answers
I would suggest going to Makitatools.com and typing in your model number to look at a schematic. It could be numerous things that are wrong. I would think a bearing is going bad, but take a look and let me know and I will see what I can do.
Posted on Jan 12, 2009
  • David Ford
    David Ford Jan 13, 2009
    If this tool is in fact a Makita product I would go to Makitatools.com and look at a schematic. To find out if it a bearing if you are comfortable with the disassembly after looking at breakdown you can hold the bearing in one hand and spin the armature with the other it should roll freely. Also look for the outer race being loose.. Let me know if I can help further
Coffee beans are not going into grinder.
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
Jun 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Display reads fill beans, but bean are filled. I also took them all out thinking something was lodged in there, Turned machine on and off, switched settings and still says fill beans.
This sounds like the grinder is not strong enough to grind properly. Try adjust the grind to a bit coarser, if this makes no difference then the bearings inside the grinder may gone. Try only fill a small amount of beans in the container and see if it works. It may be that when there is too much of a load on it it will not spin the blades.
Mar 28, 2011 | Jura Capresso ENA 4 (13421)
I received a new lower burr grinder part from SAECO for my machine but no instructions on how to replace it. I know how to clean and replace the removable grinder part that fits into this. Do you have...
Hi
If you only got the lower burr it won't work. They should be matching burrs.
If you don't do it right, you will damage the grinder. You need a #10 Torex bit.
Insert the bit into the screw in the middle of a very clean grinder. Turn clockwise to loosen. Once the screw is out, pull the burr out, but be careful. There are ball bearings and springs under the burr. Make sure that everything is clean before reassembly. There are 3 holes in the bottom of the grinder. The springs go into the holes first. Then the ball bearings set on top of the springs. Place the new lower burr on top of the springs. A washer and the corkscrew go in next. Insert the screw in and with the bit in place turn (with a little down force) clockwise until the screw drops into place, then turn counterclockwise. It should turn fairly easy. Once you start putting pressure on the springs, try to turn the corkscrew. There is a notch that it slips into in the bottom of the grinder. Once it locks into place keep turning the screw until you start to turn the burr. That should be tight enough. Now reassemble the top burr and adjust.
May 12, 2010 | Saeco Vienna SuperAutomatica Coffee...
Cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Feb 06, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Door wont open from inside or outside
I have just fixed mine. You have to remove the rear seat then remove the side panel that the door is jammed on.Now looking at the door post you will see two screw heads that are crome in colour. I took a small grinder and took of some of the length of the screw These two screws is what holds the door latch to the body which holds the door closed I then drilled a hole threw the bracket and the screws both screws then broke the bracket loose,pushed the screws in and the door opened.Had to buy a new lock assembly from a wrecking yard and took out the to screws I drilled out.of the same car I got the lock assembly Good Luck It worked for me
Jan 19, 2010 | 1998 Volkswagen Beetle
Dishwasher acts up
sounds like you have a bad chopper. put a cup upright on the top rack. turn the dishwasher on let it wash for about 2 minutes. open the door and see if the cup has water in it. let me know. what brand is this?
Jun 15, 2009 | Dishwashers
Full of Beans
You have to mount a resistance on the power card.
/Mirran
Aug 24, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Replacing micro switch
You have to take of the top, there are several screw to loosen.
  1. Take off the water tank and bean hopper
  2. Take out drip tray and dregbox
  3. loosen the two screw in front where the dregbox and driptray was ( one in each corner)
  4. Take of the plastic adjustment in the right corner (grinder adjustment)
  5. Loosen the screw in chassi where the water tank was, look inside where the beanhopper was to make sure there not are a screw, some models have one there. If there are one you will see that behind the grinder.
  6. Take off the plastic on your steam pipe.
  7. Take off the top.
  8. On the right side near the hole where you put pregrounded coffee, there will be a little microswitch.
I hope this will help you
Jul 14, 2008 | Saeco Royal Digital Plus Coffee...
Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
Take apart
My grinder went from bad to worse and finally stopped grinding (with the motor still buzzing but absolutely no grinding). Knowing I had to do something or throw it away, I pulled the clear plastic bean reservoir upward and separated it from the grinder body. I looked down the hole where beans go down to the grinder and found packed coffee ground blocking the hole. I cleaned the whole thing, put the reservoir back, and my grinder now works like new :-)
Oct 27, 2007 | Braun KMM 30 Electric Burr Grinder
Makita 9553NB 4" Angle Grinder Logo
163 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
