Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
NO PICTURE, NO SOUND AND LANP GOES OUT AFTER STARTUP
  • 1 more comment
  • BRUCE HAYS Dec 08, 2012
    THIS IS FOR SD TEC: THE LAMP IS OEM (REPLACED ABOUT 3 YR AGO. MAIN CHASSY
    FOR SD TEC: THE MAIN CHASSE WAS SWAPED OUT (IT WAS USED BUT CHECKED OUT)
    FANS ARE SPINNING , COLOR WEEL IS TURNING, BUT SAME PROBLEM STILL EXISTS
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
We will presume the lamp is good and not the problem---let me know when last replaced and if a generic or OEM lamp.
This leaves a few suspects other than a power supply issue---The ballast is one but not real likely if lamp makes it on even for a short time, Do we when the lamp comes on hear any high pitched whine or grinding or fan like sounds (not the fan itself but something that sounds like it?)
About the only other simple cause would be the color wheel which faces the lamp---if not turning, or too slow, of pieces missing it can do this---It will cause the set to detect no wheel movement or too slow and turn lamp off and set with it.
Look with lamp removed where the lamp faces--worth a look.
NO PICTURE, NO SOUND AND LANP GOES OUT AFTER START - 12_7_2012_3_48_03_pm.jpgThis is one from a Samsung but all of them look pretty much the same.
Posted on Dec 07, 2012
New lanp and tv is green
Most likely optical light engine is damaged--GOOGLE the model number with "problems" or "Light engine".
Jun 05, 2012 | Mitsubishi WD-62725 62" Rear Projection...
My screen is black with no picture
If you turn on the computer and the lights come on and the fans start but you see no picture, try turning up your volume to listen for the windows startup sound. If you hear the windows startup sound it is likely your video card or the monitor on the laptop. If you hear no sound the power could be faulty or the computer could be completely fried. Follow this link to get your laptop taken care of by HP http://h71036.www7.hp.com/hho/cache/405979-0-0-225-121.html
Mar 15, 2011 | HP Compaq nc6120 Notebook
Black picture and then sc-302
sc sounds like a scanner code check and see if scan lanp is on when copying. just lift the top cover and hit copy.
Jan 22, 2011 | Gestetner Office Equipment & Supplies
Screen comes on ... no sound or picture only header info, at top with channel info.... then the screen goes dark not any thing .
The power supply startup resistors on the inverter board may have changed values. Youwill have to replace the inverter board. Thanks for asking !
Aug 04, 2010 | SNK Magnavox 32MF338B27 32 in. LCD TV
Shuts on and off constantly. Lanp light blinking. Sound but no picture.
I would suggest if you haven't done so alreay is replace the projection lamp. The symptom you are describing indicates a failing lamp. The lamp part number will be located on a orange and white sticker on the side and it will say LAMP CODE and will start with a number of BP96-. If the sticker is missing then you will have to remove the lamp from the TV and get the number off of the cage of it. Please take a moment to rate my answer. Thanks....
Nov 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
How can i check my lamp ballast in a rca scenium 50w151 everyone tells me its my color wheel because i replaced my lamp and since then my tv wont even start up the light blinks then it stays on for a while...
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
(AKA) (TECHMAN)
Sep 04, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Dell Monitor comes on but no picture
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
Jan 16, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
