Question about Pyramid Magic-pro Igogo Tv - Android Tv-box Built-in Webcam Mic
Air mouse erratic cursor movement
I have this MP 188 model of android tv box with a serious erratic movement of it's cursor on screen. I noticed this malfunction since the first drainage of the original batteries. I did changed the batterries, but still the cursor moving uncooperative. I really need it to be fixed very badly because it's gonna be useless and very annoying. I hope you can advise me in anyhow or you can suggest any brand that will replace my current remote control. Many thanks.
Cursor freezes or is erratic
Ow, I have had this problem myself. Do you have an iPhone or other Apple device that you've connected lately?
I am assuming your mouse is either Bluetooth or uses a proprietary 'dobgle'...Which?
Dec 28, 2013 | Computers & Internet
Erratic cursor ms media centre wireless keyboard
What platform? Memory (needed for this sort of task)? WiFi gateway? Model?
Importantly, have you attached any Apple devices to your system recently?
If the connection is Bluetooth (to TV), well, there's not much help for it. You need a lot of CPU and Memory for smooth flow and device functionality.
On my CF-51 the touchpad is erratic and occasionally the screen cursor will jump. The OS is Windows XP. Everything else works perfectly.
I had similar issues with cursor jumping even while using a mouse.
Very simple & quick fix is to simply "disable" touch pad through "start up" mode use a mouse.
You have to disable in start up menu or pad will re-enable itself next time you boot.
I never liked a mouse before being forced to use it .... now it's not so bad.
Jun 22, 2011 | Panasonic Toughbook CF-51 Notebook
My mouse does not works properly/ it works slow, cursor makes little jumps, movement not smooth. Laptop samsung R40
Are you using it on a mousepad? If not, that is probably why you are getting jumpy and erratic movement. Put a mousepad underneath the mouse and you should see the cursor movement improve.
You can also adjust the mouse properties such as speed and control by going into the Control Panel and opening the Mouse applet.
Do you have the correct Dynex driver installed? If not, go to the Dynex website and download the driver for your mouse. Having the wrong driver (or a generic driver) can make a difference in performance sometimes.
Hope one (or all) of those solutions helps!
Jul 08, 2010 | Dynex Wireless Optical Laptop Mouse...
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Mouse is erratic in its movement
Go to Logitech site and load newest software for that model. After you do this, you can customize to windows by going to control panel, mouse, etc. Hope this helps.
Jul 06, 2009 | Logitech 9311570403 Mouse
Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
May 11, 2009 | Computers & Internet
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Pyramid Magic-pro Igogo Tv - Android Tv-box Built-in Webcam Mic Logo
Top Pyramid Video Cameras Experts
Are you a Pyramid Video Camera Expert? Answer questions, earn points and help others
