Question about Minolta Office Equipment & Supplies
Minolta ep 5000 error c0072 - Minolta Office Equipment & Supplies
  • Minolta Expert
  • 1,326 Answers
A C0072 error code deals with the toner bottle. Remove the toner bottle and close the front door and let the machine warm up. Make one copy and install the toner bottle again. The toner holder may have not been in the correct position. If it continues, you may need to call a service person. Good Luck
Posted on Jan 13, 2014
2 Suggested Answers
SOURCE: Minolta EP 6000 error code
Error code CO200. What is this.
Posted on Aug 12, 2011
C0072 copy error
The error code C0072 deals with the toner hopper. I would remove the toner bottle and close the front door and wait till the copier comes to ready and make a copy, if it works install the toner and see what happens. The problem may be in the toner bottle holder.... There is a "HP" sensor that may be dirty or broken. Good Luck
Nov 05, 2013 | Minolta EP4000/5000 CS/PRO Copier
Code c0072 at Minolta ep 4000
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the cover and turn on the machine. Let the machine go through it normal routine. IF code appears open close front door,When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Sep 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPRO EP 3050 CODE ERROR C0072
Sir/Mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Aug 28, 2013 | Minolta EP4000/5000 CS/PRO Copier
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
I have received code C0072? what can I do to
The toner bottle is in wrong, take out the toner bottle and close the front door. wait until the motor stops running or until the copier asks for toner. open the door, the bottle should go in with the hole up.
Jan 27, 2010 | Minolta EP4000/5000 CS/PRO Copier
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
147 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
