Question about GPS
I have mio s600 and during the travel the car charger has stopped working, so the navigation automatically started to use it's one battery. After I pulled out the charger, and sticked it in again,
    Top Expert:
  • 14,553 Answers
If you are using the lighter plug for charging it may have a fuse inside the plug itself the plugs into the lighter socket,,,,,look for a fuse there or if have a volt meter check for voltage reaching the unit when plugged that way If voltage is good to the unit from the car source the battery may be bad, either not getting a voltage for charging or battery not holding a charge.
Posted on Dec 07, 2012
  • tiaa Dec 07, 2012
    What battery? Car battery? Isn't the car source the battery? We check the voltage of the lighter plugin, and it's ok. If you mean the battery of the navigation device, the battery holds for 2 hours.
SOURCE: map of us for mio c 220s
email me for help bmarcia115@gmail.com
Posted on Dec 12, 2008
SOURCE: the gps wont start
Have you checked the fuse in the charger?
Posted on Apr 08, 2009
  • 4090 Answers
SOURCE: destinator 8 does not aquire satelites
try using the settings and get to satellite then select autosearch It is possible your BAUD and PORT are not set correctly
Posted on Aug 01, 2009
SOURCE: my mio moov 300 is stuck in a restart routine.
install your miomore desktop software from the MIO DVD and under TOOLS you have an option called: "Reinstall software on your Mio."
Posted on Mar 12, 2010
  • 1514 Answers
SOURCE: My Garmin 760 charger appears to not be working.
It's most likely that the fuse has blown in the charger plug. Instructions complete with pictures are available from http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=DB06036F1F1FBB6DE01E21EE59D70192
Posted on Aug 13, 2010
Can't start my mio soul
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Mio won Start
Mio Wont Start In The Morning
http://www.rasterline.com/MIO%20SERVICE%20MANUAL.pdf
OEM parts for Yamaha
Yahaha MIO soul owner manual
Sep 14, 2012 | Yamaha Motorcycles
Am needing to update my Mio satnav but am having difficulty. Having connected it to my computer with the relevant usb cable and loaded the original dvd into my driver I get error messages as follows: 1 A...
Mio uses a tricky little thing to up date, If i remember right on the cd or dvd whichever one you got there should be a program called Active sync or something like that that installs under windows. This program must be running and MUST be installed for you to update any MIO product.
Make sure that this program in installed and running on your computer and then hook up your device. It should be found fairly fast by active sync. Once it has been found and device permissions setup you should be able to update following the procedures you received with the update.
Hope this helps
Jun 26, 2011 | Mitac Mio C220 GPS Receiver
I have Mio C310 it does not turn on. even pressing rest.
Plug the GPS into your car, then slide the ON/OFF switch, located on the bottom of the GPS, then set it to 'ON'. Then the system should automatically start up.
May 15, 2011 | Mitac Mio DigiWalker C310x GPS Receiver
My mio navman m300 will not turn on, its 2 months old and was working fine then suddenly would not turn on, its has not been dropped at all. any ideas??
hi,
Plug it and leave it on charge for at least 4-8h. Try both car charger and USB cable, it could be that the issue is the cable and not the battery
Nov 22, 2010 | Mio Moov M300 GPS for Europe 35" screen...
My Garmin Nuvi 270 has a charging problem. When I plug the car charger it automatically goes to computer charging mode and does not allow me to navigate and charge at the same time. I always charge the GPS...
This is because the socket in the back of the satnav is worn and prevents the mini USB plug being pushed in fully. Push it in further and it will be ok.
Oct 03, 2010 | Garmin NUVI 270 GPS Receiver
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
The gps wont start
Aug 28, 2008 | Digi MIO Walker 136 GPS Mobile Navigation
Charger light flashing, battery not charging
What you can do is call their tech support department and they should be able to replace the battery for you. Tech support will take your information and request you to send in your battery before they replace it.
Jul 23, 2007 | Casio Exilim Card EX-S600 Digital Camera
GPS Logo
76 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
