Question about LG WM-1832C Front Load Washer
Door leaks at bottom machine wm1832cw - LG WM-1832C Front Load Washer
  • whec33 Jan 15, 2009
    Need to replace the tub seal an how do I get clamp back on is there a a too.i can buy
  • 1,543 Answers
This can be caused by pushing the washer in place which can slightly bend the front panel inward (the fix would be to remove the outer clamp, outer tub seal, pull the panel slightly out, and reinstall the seal and clamp) or it might be cured with simply moving the spring part of the clamp from the bottom (6 O'clock position) to the hinge side (9 O'clock position).
Posted on Jan 12, 2009
3 Suggested Answers
  • 6 Answers
SOURCE: How do I replace my door boot seal/door gasket on
There are 2 springs attaching the door boot. The springs are really tough but there are 2 separat tools for each spring. Use the tools to remove & install. It's tough but can be done.
Posted on Nov 10, 2009
rickead1
  • 1998 Answers
SOURCE: LG Front load washer wm1832cw
hello this is the entire schematic for your machine click here http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Washer-Parts/Model-WM1832CW/3204/0153200?pathTaken=&prst=0&shdMod=WM1832CW if you remove that rear access panel locate on this diagram as part number 101 http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810334-00001.png and run the machine on the gentle cycle you should be able to determine where your leak is either the pump or the drain lines or the boot that goes into the tub i have seen so many differnt types of foriegn debris stuck in this lower boot paper clips, bra wires, pens etc these sometimes cause a puncture in this lower boot also part numbers f315 k 520 which are both bellows should also be checked for any leaks as well as the drain pump which is located at k344 if you have any further questions message me back i will be in flight from tuesday evening until thursday morning finally leaving hawaii to go back to east coast Thanking god on that note I await your reply Thanks Rick
p.s this is the last link that shows where these drain pieces are http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810334-00002.png
Posted on Mar 29, 2011
My lg wm1832cw is leaking?
it could be the water pump look in back remove inspection cover keep hands away mine leaked at the water valves
Mar 15, 2015 | LG Washing Machines
My LG WM1832CW will not start.
It looks like the door switch is bad
Apr 04, 2014 | Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
Lg washing machine wm1832cw door is locked with clothes inside
This is most likely due to non-pump out of the water. It could be a plugged filter or a bad pump motor. First thing to do is to get a pan or bucket and open the big screw filter behind the access door at the lower left on front of the machine. All the water will come pouring out, so be ready. Machine will probably unlock on it's own then. (if it is still plugged in) If not, you can take the top off by removing the screws on the bottom of the plastic clips at the back of the washers top. Now, standing in front of the machine, use the palms of your hands to sharply push the top back about an inch, then lift the top off. With machine unplugged, you can reach down to manually relaese the door lock.
Jun 08, 2010 | GE WBVH6240F Front Load Washer
LG leaking from bottom, Not the filter clean-out.
Not necessary to blame LG, ALL of these front loaders are garbage. They were designed poorly and released too soon just to have a new gimmick.
Jan 16, 2010 | LG WM2688HWM TROMM SteamWasher
How do I replace my door boot seal/door gasket on my LG WM1832CW front loading washing machine?
Nov 10, 2009 | LG WM-1832C Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
Water comes out all over the floor I have a LG wm1832cw washer and my dryer is not completley drying the flame comes on the cuts out
To find source of leak, look for a hole in the gray seal between the tub and the door. Dryer, clean out vent and make sure not to use flex venting.
Oct 23, 2008 | Washing Machines
LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Jun 17, 2008 | LG WM-1832C Front Load Washer
OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
Jan 21, 2008 | LG WM0642H Front Load
LG WM-1832C Front Load Washer Logo
219 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
