Question about Toshiba 72HM196 72" Television
LAMP COMES ON ,AND THEN GOES OUT Toshiba 72HM196 72 in. Television
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Possible bad lamp or the ballast that provides voltage to light it.
Posted on Dec 23, 2012
TV turns on then cutts off
that buzzing is the high end power trying to turn the lamp on.... the electrical current and shock is what turn your lamp on your tv which is what the buzzing is dont worry thats normal...however your solution is buy a new lamp for your tv but make sure its the right serial number for lamp u cant just buy any lamp. best place to buy one ebay.... as in the lamp still trying to light up its only because the electrical current going into the lamp and then cutting off causing the red light on your tv....so other words all it is is the lamp... CAUTION!!!! those lamps get up to 400 degrees unplug tv to ensure no electrical current.... hope i helped.... JACOB WINKLER
Jul 16, 2012 | Toshiba 46HM95 46" HDTV
So my toshiba 19av600u will start up like normal and work fine for about 2 minutes then the screen goes black, sound is gone and it acts like its caught in a loop. I can see a slight difference in the...
The problem with the television is that the lamp is bad and need to be replaced. The lamp is located at the back of the television.
Turn off the television for a while and unplug it from the power outlet, then you turn to the back of the television and unscrew it open, after doing so, take note of the lower compartment and you will see the lamp box, carefully unscrew it open and get the lamp.
Get a new lamp and fix it in the television then carefully reassemble it back together. Plug it back on the power outlet and turn it on, and it will work perfectly fine.
Hope this helped.
Goodluck
Jun 20, 2011 | Toshiba 19AV600U LCD TV
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Picture comes on then goes off it keeps doing tnis as long as the tv is on
It sounds lamp in Tv is weak and time to replace lamp.
Does green light blinks when picture goes and comes?
If yes, replace lamp, procedure is written in user manual and please buy Sony original lamp for TV safety.
Thanks.
Nov 25, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
I have a Toshiba 56hm66 and the light went so I replaced it and now it will come on for a brief instant screen lights and the the lamp shuts off and it attemps to restart the lamp and fails I can turn it...
This set will cylce 7 times until lamp comes on. Lamp could be bad. Try another lamp if still not working replace ballast. Although on this set You have to remove the light engine with the ballast and send it to Toshiba to be rebuilt.
Nov 23, 2009 | Toshiba 65HM167 65" Projection Television
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
Television problem
Try changing the lamp, as sometimes an old or weak lamp will cause this symptom. USE AN ORIGINAL SONY LAMP as the replacements are unreliable
Oct 11, 2008 | Sony KDF-E55A20 55 in. LCD Television
Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Sep 10, 2008 | Toshiba 52HM95 52" HDTV Projection...
LED green and red light blink
the ballast should make momentary arcing sound and orange flash in its spark gap tube when it 1st trys to light the lamp. look for it in the darkness it will be easier to spot, as you listen for it. make sure you are buying toshiba factory replacement lamp.
Jan 14, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 72HM196 72" Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
