Power is on but program unable to display
Even the power is already on but the program unable to display
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard Hope this helps.
Posted on Dec 08, 2012
Power is ON but unable to start program
1) You must have the deck belt is WORN, to due the lack of maintenance , however LUBE the deck belt with 100% of silicone or wax
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.see my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 10, 2012 | Exercise & Fitness
I m unable to open my bios setup utility, I hav IBM A51 8122 KQP desktop.
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
Notes:
a. If you have a USB keyboard installed on your computer and the Setup Utility does not display using this method, turn on the computer, then immediately press and release the F1 key repeatedly until the Setup Utility displays.
b. If a user password or an administrator password has been set, the Setup Utility program menu is not displayed until you type your password.
I hope this helps.
Mike
Jun 01, 2011 | IBM ThinkCentre A51 PC Desktop
When I turn my PC on you can hear it come on but the screen is black.
It sounds like you might have a problem with your video card. If you turn it on and see nothing, not even the gateway logo, than you either have a video card issue or a monitor issue. Hook up the mahine to another monitor to test.
Jan 04, 2011 | Gateway Computers & Internet
Turboc++ in full screen on vista 64 bit in dosbox
right click on the shortcut of turbo c and go to compatibly tab and choose the option of run the program in windows xp os and run as administrator .
Jan 08, 2010 | Microsoft Windows Vista Ultimate Edition
When receiving attachment that requires -power point slide show- Outlook express -cannot run it-- message pop up says "the file does not have a program associated with it for performing this action.Create...
  • Open up Windows Explorer. (The Windows Key + E, on many keyboards.)
  • Find any file with the PPS extension. For example somefile.pps.
  • Right-click on the filename, and select Open With ....
  • Even if the PowerPoint or PowerPoint Viewer is already listed don't click on it. Instead, select Choose Program at the bottom of the list that's displayed.
  • In the resulting dialog box you should find PowerPoint, or PowerPoint Viewer, and click on that.
  • Click the box labeled "Always use the selected program to open this kind of file".
  • Press OK
Jul 10, 2009 | Computers & Internet
How to unlock LG dvd/vcr model no/ v782w
try that:
  1. Power on (with no disc inserted)
  2. Press PAUSE
  3. Press 3, 1, 4, 1, 5, 9
  4. Enter the desired RC
  5. Press PAUSE
  6. Turn the player off and wait a few seconds
  1. VCD playback
  2. Press PAUSE, 1, 4, 7, 2
  3. Press UP 6 times, '07 00' should appear on the display
  4. Press Program 6, Program 5 ('07 FE' should be displayed)
  5. Press ENTER
  6. Press RETURN
  7. Power off and on again
Dec 28, 2008 | LG V181 DVD Player/VCR
Problem with the cap on the lens of digital camera SONY CYBERSHOT DSC P52
I have loaded the program into my computer but am unable to bring up the photo, I think i need a new disc as it says it is corrupted, but I do not know where to get one.
Dec 18, 2007 | Cameras
CD player stucks at READING
www.funai.us
Customer Support Representatives may also be reached by telephone at 800-242-7158
Jul 09, 2007 | TruTech TT1620 DVD Recorder
Computers & Internet Logo
David Payne
David Payne
