Internal battery message 601
After replacing battery with same model, the message still appears on strating up.
  • 7,627 Answers
Did you purchase the battery from you Computer's website? Take a look at this: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01443470
Posted on Dec 07, 2012
caroldon
  • 17130 Answers
SOURCE: I have internal battery 601
This is the bios battery which back up the clock and settings and it is normally found on the main motherboard accessable from the rear of the laptop from the memory card opening.
so remove and fix the 3 volt battery into the slot.
Posted on Sep 28, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I keep getting ;messages saying
This sounds like the error you would get on an IBM thinkpad or Lenovo laptop.
There are third party sources for these all over the place.
As an example, I own an IBM thinkpad model A20M.
If I google a20m CMOS battery, I am sure to find a plethora of sources online.
Being Canadian, I go to Ever Corperation at www.evercorp.com for any replacement batteries I need.
Make sure when you order your battery that you aren't ordering the main battery pack, and are indeed ordering the CMOS battery.
Installation instructions should arrive with the battery.
Posted on Jun 04, 2011
  • 11800 Answers
SOURCE: when I turn on my
the battery of the laptop has aged and you must replace it with a new one -order it at the ones that sold it to you.
Posted on Aug 23, 2011
joecoolvette
  • 5660 Answers
SOURCE: hp notebook G61 primary internal battery replacement
1) Remove ALL power. Remove the AC adapter (Charger) and Battery. (Main battery)
2) Lay a soft static free cloth on a table, lay the laptop upside down on it, Battery Compartment facing AWAY from you.
3) Remove the Harddrive Bay Cover.
This is the large rectangular cover nearest you.
Two Philips head screws are loosened all the way, on the Right side of the cover. Then the right side of the cover is lifted up. (The Left side has plastic tabs. Swing the cover up, and out )
4) Three Philips head screws hold the Harddrive Caddy in. One on the right side, two on the left.
Remove the screws.
Grasp the Mylar tab on the Harddrive Caddy, and pull to the right.
This disengages the Harddrive from the interface of the motherboard.
Lift the Harddrive up, and out.
5) The RTC Battery is under the Harddrive Caddy.
Real Time Clock Battery.
Plugs in with a white connector, on the end of it's Black, and Red wires.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 12, 2012
Geekman
  • 32281 Answers
SOURCE: is the internal battery 601 in the HP Pavilion dv7 the cmos battery?
Yes, most computers have one, it keeps the the BIOS settings when the power is removed.
Posted on May 05, 2012
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Internal battery 601
Replacing the bios battery will fix that.
Jul 14, 2014 | Computers & Internet
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
601 internal battery error
Replace the battery. See utube for video instruction; type in your model and 'CMOS battery replacement', in the search box.
Jul 11, 2012 | HP EliteBook 6930p Notebook PC
Internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Jun 16, 2012 | HP Compaq 6735s Notebook
I keep getting ;messages saying I need to replace the internal battery 601/ Can I buy that online?
Jun 04, 2011 | Computers & Internet
I have internal battery 601 problem need new battery message. when i turn on it boots up then before i can check the external battery level it switches off. So i start again with mains plugged in and the...
Sep 28, 2010 | Computers & Internet
Open Questions:
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
