Question about Brother MFC Office Equipment & Supplies
No paper fed reload paper then press start - MFC Brother Office Equipment & Supplies
4 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: i have a brother copy/fax/print
lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
Posted on May 15, 2008
freetek
  • 5568 Answers
SOURCE: My DCP-560CN printer
Do you hear the paper feed motor at all?
If not, either the drive electronics or the motor has failed with the latter being the least likely.
If you do hear it, the pickup roller is probably gotten loaded with paper fiber (there is a difference between cheap papers) or has dried out on its surface. If it seems to be working, take a clean sheet of paper, make a fat line across it about two thirds down from the top with pure alcohol or methanol (don't use 'rubbing alcohol' diluted with water), feed the paper into the machine and stop the paper several times as it is pulled through to try to get the wetted strip stopped on the pickup roller to hoopefully clean it. To get the machine to feed, send it a blank page from any text editor. If it still won't pick up the paper, you will have to gain access to the innards and locate the first roller in the paper path and, if possible, remove it and using a coarse wood file, roughen the roller. Depending on the type of rubber, this can produce tiny 'fingers' of rubber sticking out which will grip the paper better. Pay attention though to turn the roller in the direction of normal operation to produce a surface with 'fingers' that will catch the paper.
Many printers develop that problem with use and it has been serious enough in some older HP models that they designed a special fixture and a small software program that did the same as I suggested with the file. This can be done several times without reducing the roller diameter too far.
Posted on Oct 06, 2008
  • 16 Answers
SOURCE: no paper fed reload paper
The paper detect sensor could have dirt in it. Blow canned air directly on the sensor and try again. Asides from the sensor being bad the actuator for the sensor could be broken.
Posted on Sep 11, 2009
I have a Brother model HL-2040. The printer was working fine. I put some additional paper in it and clicked print and all the lights started flashing. I looked for a paper in the printer wrong and...
Red paper light is on means that there is no paper fed in the machine. Follow the steps below to clear this issue:
- First remove the paper tray from the machine. - Then remove all the paper from the tray. - Fan the paper well or run your fingers through the edges of the paper. - Adjust the paper guides of the tray. - Then reload the paper back to the paper tray. - Put the paper tray back to the machine. - Lastly press the go/blue button.
Printer should print the document.
Hope this helps. Rate if it works. Thanks
May 09, 2011 | Brother Office Equipment & Supplies
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP officejet Pro L7680 cannot scan anymore. It keeps saying: "Reload the Document & restart the job. And when scaning through PC then give an error msg: "The automatic Document deeder is...
does the feeder try to fed the paper? if you hear not working and not fed the paper then clean with alcohol with hard paper the roller .
if not fix did you hear noises? maybe the gears.
hope i help
Dec 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
Sep 11, 2009 | Office Equipment & Supplies
"No paper Fed"
Check the paper cassette and make sure the paper stop is flush up against the paper if it's not push it up against the paper and try again to print.
Aug 11, 2009 | Brother MFC-7220 All-In-One Laser Printer
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Oct 21, 2008 | Office Equipment & Supplies
I have a brother copy/fax/print MFC 5860. i am unable to print. no paper jam..the screen reads: no paper fed #2. reload paper, then press start. i have paper in both paper trays and have autoselect...
May 15, 2008 | Brother Office Equipment & Supplies
131 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
