Question about Cell Phones
Format sd card files recovery by using nokia c2-01
SOURCE: memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Posted on Nov 03, 2008
SOURCE: Format an SD Card for Nokia 5300
Sorry to say, but the phone only supports upto 2GB for the micro SD card. So it wont work whatever you do.
Posted on May 14, 2009
spymohit
  • 111 Answers
SOURCE: Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
Posted on May 30, 2009
satishcool7
  • 511 Answers
SOURCE: i want to use micro sd card using with adapter in nokia 6600
try to format the micro sd card from mobile it will take time but do it ..
Posted on Sep 06, 2009
SOURCE: format micro sd on nokia 6085
Same here. I just posted on the Nokia discussion site also but if the problem hasn't been solved by now, my guess is that it's a Nokia or AT&T screwup.
Posted on Oct 13, 2009
I want to recover my moble n95 data
I had success recover files from mobile phone with this mobile data recovery guide, check it out
how to recover deleted files from mobile phone
hope this helps.
Dec 26, 2012 | Nokia N95 Cellular Phone
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
All you have to do is
Step One (save data)
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Method 2
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
I hope this information helps. Thank you for using FixYa!
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
I badly need to retrieve deleted SMS on Nokia 6700 slide set.
You may try asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Jun 28, 2011 | Nokia 6700 Classic Cell Phone
My mmc card corrupted. there is important files hence i get that files without formatting
you can try some data recovery software. You can see
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Mar 07, 2011 | Nokia 6600
How to recover deleted text messages from Nokia e63 memory
you can recover lost info from phone with mobile phone recovery software, recommended asoftech data recovery as it helped me beforehttp://www.asoftech.com/adr/
Dec 28, 2010 | Nokia E63 Cell Phone
When im reformat my 1gb micro sd,my all data will be deleted...is there any chance to recover or back my deleted file coz of reformatt?
you can recover photos after reformat with asoftech photo recovery software, you can follow the steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download asoftech photo recovery software
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Dec 22, 2010 | SanDisk 1GB microSD Memory Card
I wanted to check the amount of storage left on my zoom h4n sd card. I went into the sd card file via the zoom h4n menu and it asked me if I wanted to format the sd card. I tried to select 'no' but the...
You may try some recovery software to rescue the files on your handy recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the recorder in case the original files(your recordings) are overwritten.
Apr 19, 2010 | Zoom H4 Handy Recorder
I have a aiptek by mistake i format the sd card i'm able to recover jpg files but the mov files are broken, I have searched only and the reason is because that camera creates mov hd h.264. I need help to...
You may need to try some photo recovery software to rescue the pictures, here are some for your option. You may not recover all the pictures, but will recover most of them.
Photo Recovery (for Windows)
Photo Recovery for Mac
Both programs are able to recover pictures, videos and music files.
Note: Before your files are recovered, do not attempt to save more files to the SD card in case the original lost files are overwritten.
Jan 26, 2010 | Aiptek PocketCam DV Digital Camera
SD card
recover files from sd card
If above does not work, you may have to format the memory card (use quick format), and then use sd card recovery software to scan again the memory card and recover your files.
Jan 24, 2008 | JVC Everio GZ-MG130 Camcorder
Cell Phones Logo
113 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
