Question about Mitsubishi WD-60735 Projection Television
Mitsubishi wd-60735 replaced lamp. tv still wont come on. orange flashing light
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This set should have a self check:
Posted on Dec 07, 2012
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
  • 8457 Answers
SOURCE: How do you change the lamp in a Mitsubishi model
Try website like Youtube.com,search type in ur tv model,make and projection lamp replacement.U will have somebody,have a tutoring video doing it.
Posted on Oct 04, 2010
SOURCE: i just replaced the bulb
IT NEED A red flashing lampTO WORK
Posted on Jul 07, 2011
  • 26 Answers
SOURCE: Mitsubishi wd-60735 no picture and red lamp light
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Posted on Oct 07, 2011
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
-- "wd-60735 lamp was replaced have sound but no
check your Lamp Fan if it stops running when Lamp trys to light ,then it is defective ,but if it is ok Ballast Board could be the problem, it is what Powers the Lamp ON.
Aug 23, 2011 | Mitsubishi WD-60735 Projection Television
Replaced bulb in are mitsubishi (WD-60735) now has yellow light and wont turn on it was not the filter cleaned it need help!!!!!!!
Recheck the the tv safety switch it is not on or a little warp before u put it back and closed the door to the tv projection lamp compartment?Yes,than this tv also have a dead boad that is call the Ballast board,must be replace too.This Ballast board only job are to help to ignite the tv projection lamp only.
Jul 14, 2011 | Mitsubishi WD-60735 Projection Television
My WD- 60735 mitsubishi tv will come on and work properly for about 5-10 mins then shut its self off. A orange light will flash 1-3 times then go green and blink for a period of time, what is the prblem?
Count the number of flashes of the green light and make note if there is a sequence. Google WD-60735 blink codes. This will send you to a number of links to choose from. The blink code will tell you what is wrong with your tv.
May 08, 2011 | Mitsubishi WS-55859 55" Rear Projection...
How do you change the lamp in a Mitsubishi model WD 60735 projection TV
Oct 04, 2010 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
Aug 14, 2010 | Mitsubishi WD-60735 Projection Television
I have a DLP mitsubishiWD-60735 will not power up the green light just keep flashing tried resetting the system didn't work
Replace Lamp Call Mats Electronics 1-800-628-118 or Encompass Parts for listing to all Parts for your TV 1-800-638-3328 or Go to their website.
Nov 13, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
