Question about Vizio VW32L 32 in. LCD HDTV
VW32L Vizio TV no power ,Vizio letters do not light up,fuse ok
Fuse ok
  • Vizio Master
  • 933 Answers
Sounds like you have a defective power supply
Posted on Dec 07, 2012
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
  • 6 Answers
SOURCE: Amber light issue vw32l lcd Vizio
Its easier to open up your tv, look at the mainboard id number. Then do a search on google or ebay for the parts. Its alot easier then trying to troubleshoot the actual circuit board, unless your an electronic engineer.
Posted on Jul 19, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Vizio VX37l and was watching it and then
It sounds like the 5vdc standby circuit is still working, that is why the main fuse is still good but you may have bad 24vdc power supply, look real close again for blown transistors or IC on the power supply board, but it can also be the backlight inverter circuit boards that blew up also. Look here to see what good parts look like: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX37L+
Please post back what you find.
Posted on Dec 08, 2009
Why my tv won't come on? it's plugged inand no light or any thing is happening
Salvador, Could be a internal board issue or power supply, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Official VIZIO Support
Fix Power Problems In 5 Easy Steps What To Do When Your Vizio TV Wont...
https://answers.yahoo.com/question/index?qid=20120504055328AAiBGKi
Oct 28, 2015 | Vizio Sanyo, Ssi320wf12 / Vw32l Hdtv10a...
When plugged in, why do only the Vizio letters on the front light up in amber?
There could be an open fuse off board. The lighted Vizio letters merely confirm power is getting to the TV.
Jul 28, 2015 | Vizio VX32L Television
Thunder storm last night
have u made sure that the out let has power yet? if not check fuse box.
next, if has power to outlet, manually press power button not remote controll, after it has been unplugged for some time. view the back pannel of tv. and see if there is a fuse or fuse notification. follow manufactuar or owners manual instructions from here, google vizio support or call 888 849 4623 with model and info ready
Jul 13, 2012 | Vizio VW32L 32 in. LCD HDTV
Vizio tv will not power up.
Check the fuse if good or busted.
Jul 05, 2011 | Vizio VW32L 32 in. LCD HDTV
I have a VW32L HDTV, it just stopped working we were watching a movie and then nothing. The electrical outlet is fine we plugged something else in and it works. I keep finding suggestions that I should...
I have the exact same tv with the exact same problem while watching a movie than blam nothing. Un-screw the back panel. once you have removed it follow the wires from the female power cord connection up to the power supply. you will see a Ceramic fuse. 5 amp 250v. hope that helps
Nov 26, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio vw32L-HDTV20A-NO POWER :fuse and q101 q102 bad
You can find these fuses at the Littlefuse web site and look for Part Number: 0215008 it will also give a list of distributers like Newark where you can buy them on line for about $1.00 each.
Oct 13, 2010 | Vizio L32 32 in. LCD HDTV
There is weird letters popping up on the screen
Ok..........un plug the set and your cable or sat reciever.........plug back in to reboot both........be sure your set up shows captions and text "off"
Next step if this does not solve is to play a dvd and see if ok. this will separate the tv from your cable or sat reciever. If still continues your set may have corrupted data in the eeprom and need main board. Try the ez stuff first!!
Jun 04, 2010 | Vizio VW32L 32 in. LCD HDTV
Tv will not turn on. no power. there is power
check the fuse of your tv main power socket...might burnt
Aug 06, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio VW32L 32 in. LCD HDTV Logo
260 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
