Question about Kodak ESP 5250 All-in-One Printer
Reattach ribbon cable on print head Kodak
Ribbon cable came loose from my printer. Just wondering how to reattach it back on the print head. The other two cables seem to be fine. There are three cables in total on the print head.
IB4G2008
  • 3587 Answers
SOURCE: Kodak EasyShare Printer dock prints bottom half of picture
does this happen with the test page, too?
Posted on Feb 27, 2008
SOURCE: kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Posted on May 04, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Kodak 5300 printer problem
I would suggest the following :
1) Remove the Kodak printer and all its software.
2) Disconnect the USB cable from the computer.
3) Reinstall the entire software applications for the printer just as if you were installing it for the first time.
4) When asked to connect the printer .. Use a different USB port .. even if you have to switch something out .. but do this step irregardless.
Now what I want to know is ..
1) Can you print from the computer?
2) Black still "gone" ?
Let me know
Posted on Feb 01, 2009
SOURCE: kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
Posted on Apr 19, 2009
  • 295 Answers
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Posted on Jul 27, 2009
Kodak esp 2150 white ribbon came apart from printer head
The ribbon cable is reinstalled by sliding it into the connector
Oct 18, 2016 | Kodak ESP 2150SE Wireless Office...
Disconnected white cable
if it is a flat cable some of them had a little clip that would slide back allowing you to reattach the cable some do not
Jan 29, 2014 | Kodak ESP Office 2150 Wireless All-In-One...
HP 2175 all in one. I have a carriage jam that will not clear. There is no paper jammed anywhere. I have been through all that and I have tried all the reset options but nothing works. But I notice a...
Not sure about your model. But that ribbon is very likely the cord that send information to your print cartridge. It is supposed to be slack so that the print cartridges can move left and right. If you are able to reconnect it and make it stay you should be good. Likely when it is in the furthest position it is getting too tight and coming loose again. Hopes this helps.
Mar 11, 2017 | HP PSC 2175 All-In-One InkJet Printer
The print carriage travels along a thin plastic ribbon cable which is normally attached at either end of the print area by 2 metal 'pins'. This ribbon cable has become unattached at both ends. I see how to...
You have to remove most of the casing to access the workings. It is a tricky job as bits all plastic, click together with push fit plastic locks, and of course an occassional hidden screw.
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Epson Artisan 800 continually indicating paper jam error--No jam.
Yes, that fixed the problem on my Artisan 800! Thanks so much for the info about slipping the cr scale back onto the u-guide on the back of the print head carriage, Larry P and dabaker!
For those trying this, the u clip is upside down so, from the front of the printer, you move the CR scale ribbon down a little and in towards you gently, in from the back towards the lower part of the rear of the print head assembly, and it will slip in on the top part of the ribbon into the u shaped groove (which, to be technical, looks more like an n-shaped groove, an upside down u). If it is loose and not clipped in, the CR scale ribbon will bow out easily on both sides of the print head carraige when lightly pressed towards the back of the printer near either side of the print head. (As pointed out in the service manual, do not touch the ribbon with your fingers, particularly if they may be greasy/greasty/gritty; use a clean tool for this-I used a q-tip which worked well for both testing the tension and for pushing it down and back into the proper guide slot.) If the CR scale ribbon is clipped in properly to the print head (properly seated in the n-shaped slot), it will bow towards the back of printer easily ONLY on the side that your press it from (ie left or right) but not on the opposite side of the carriage; the opposite side will remain almost entirely flush to the rear of the print assembly. Remember to press gently; you do not want to stretch or damage this scale ribbon if you can help it. If you have a small dental mirror and good light, you will be able to see the n-shapped clip (it's plastic and black on my 800 clearly. If the ribbon is correctly seated, it will be in the slot at the top and free at the bottom. Because of the use of u-slot in the previous posts, I was confused as to where to fit this in but then figured, nothing to lose and yep, it's actually the n-shaped slot at the top.
Jul 12, 2010 | Epson Artisan 800 All-In-One InkJet...
The printer just says initializing and doesn't do
There is a ribbon that should be securely-attached to the back of the print-head -- if it has broken-loose, then the print-head will not move, even when the ribbon is moving.
Take the printer to a qualified technician to confirm this diagnosis,
and to evaluate whether the printer is "fatally" broken.
Dec 01, 2009 | HP PSC 1610 All-In-One InkJet Printer
Print problem
Are you using dot matrix printer ? related to your statement that you've change the ribbon.
It's could be problem with printer's print head, could be one or more
pins are broken
Sep 14, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Thermal ribbons broke in dye sub printer
hi,
by ripped, do you mean that the ribbons have come off the hinges or are they torn?
if they are torn, any small cracks or torn edges will not harm much. but if the ribbon is sliced to pieces, they have to be replaced, as you cannot work with torn ribbon. here is a link to the manual with which you can replace the ribbons.
cheers
Jul 26, 2009 | Kodak PROFESSIONAL 9810 Thermal Photo...
Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
May 12, 2009 | Fargo 4250 Thermal Printer
Oki 520 missing print
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit. Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Apr 10, 2007 | OKI MICROLINE 520 Matrix Printer
Kodak ESP 5250 All-in-One Printer Logo
543 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
