Question about Toshiba 42 42SL417U 42 LCD TV
Tohiba 42" flatscreen, model # 42sl417u
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Have if you can a look at the power supply board for signs of damaged parts and do not over look the filter caps there---see typical bad ones from mild to extreme:
Posted on Dec 07, 2012
5 Suggested Answers
  • 148 Answers
SOURCE: I have a 3 years old 42
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ...If this helped (or not )please rate,thank you!2c66514.jpg
Posted on Feb 03, 2010
eagle338
  • 4889 Answers
Did you try connecting a pair of headphones to see if the problem persists?
Posted on Aug 29, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a 42'" LCD. IT IS ABOUT 3 AND 1/2years old.
Hi evansw591,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 25, 2011
Testimonial: "Thank you for your answer. you displayed a very professional attitude in your effort to help."
DigitalPlus1
  • 105 Answers
SOURCE: 42 inch Toshiba Plasma TV has sound but no
That popping sound is usually a capacitor or "cap". Depending on what board it was on, would depend on what needs to be replaced. Usually its the main "power" board. I would say it probably would be worth replacing as these boards are generally not that expensive. If you take the back of the TV off, you can look at the boards. Caps are cylindrical and are various heights and widths. However they should have a flat top and bottom. Look for one that has a round top or bottom. Do NOT touch the boards though. Caps can store energy long after the TV has been unplugged and static electricity can damage sensitive chips.
Please rate if this was helpful
Posted on Apr 05, 2011
Toshiba 42SL417U doesnt respond to remote and shuts off
you have a bad power supply or mainboard causing the shutdown most likely the mainboard.
Mar 02, 2013 | Toshiba 42sl417 42 1080p Led Tv 42sl417u /...
I have SONY BRAVIA KDL 42". The screen went black and it says: programy nie zostaly zapisane. How do I go back to waching tv??
sounds like the main system has got a fault. think you will need to find the service code to go to the service menu. I don't know the service code for this model.
Dec 10, 2012 | Sony BRAVIA KDL-46V3000 Television
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
New Lg 42" plasma flatscreen
How new is it? Usually these TVs have a cool-down period, but a warm up of longer than 15 seconds is unusual. I would return it or try to get it fixed under warranty.
Mar 08, 2011 | LG Televison & Video
I just bought a philips 42" flatscreen TV model #42ef73208-37 and it won't turn on. I have a red blinking indicator light but the TV won't turn on, what can be the issue?
  • Your TV has a protective mode in case there is too much heat build-up.
  • Check the clearance around the vents of the device to be certain there are no blocking walls or cabinetswhich would limit the air flow.
  • • Check that the TV’s AC power cord is plugged into the mains socket.
    • Unplug the television, wait for 60 seconds.
    Then re-insert plug into the mains socket and turn on the television again.
If that fails take it back.. Good luck
Sep 09, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba 42 42SL417U 42 LCD TV Logo
212 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
